Introducción
Internal components of a cell phone device are protected by a plastic frame (i.e. motherboard, keyboard, screen, etc.)
Partes
No se requieren partes.
Flip the phone over to have the rear cover facing up.
  • Flip the phone over to have the rear cover facing up.
    • The camera lens should be towards the top of the phone.
Agregar Comentario
Slide the cover up, towards the top of phone, to unlock the battery cover. Lift the cover off phone and remove it.
  • Slide the cover up, towards the top of phone, to unlock the battery cover.
  • Lift the cover off phone and remove it.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Use your finger to push the top of the battery downwards and lift the battery out of the phone. Use your finger to push the top of the battery downwards and lift the battery out of the phone. Use your finger to push the top of the battery downwards and lift the battery out of the phone.
  • Use your finger to push the top of the battery downwards and lift the battery out of the phone.
Agregar Comentario
Remove the six Torx #5 screws that are securing the rear frame. Remove the six Torx #5 screws that are securing the rear frame. Remove the six Torx #5 screws that are securing the rear frame.
  • Remove the six Torx #5 screws that are securing the rear frame.
Agregar Comentario
Pry the frame open, releasing the eight plastic tabs around the edge of the frame, using the plastic opening tool. A plastic card can be used instead of the plastic opening tool. A plastic card can be used instead of the plastic opening tool.
  • Pry the frame open, releasing the eight plastic tabs around the edge of the frame, using the plastic opening tool.
    • A plastic card can be used instead of the plastic opening tool.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Marco Jokada
Miembro Desde 28/04/11
247 Reputación
6 Guías creadas
Equipo
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 1,291
