Saltar al contenido principal
HTC One M8 Headphone Jack/Micro USB Board Replacement
Qué necesitas
  1. HTC One M8 Headphone Jack/Micro USB Board Replacement, SIM Card: paso 1, imagen 1 de 2 HTC One M8 Headphone Jack/Micro USB Board Replacement, SIM Card: paso 1, imagen 2 de 2
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located on the upper left hand side of the phone.
    • Press to eject the tray.
    • This may require a significant amount of force.
  2. HTC One M8 Headphone Jack/Micro USB Board Replacement: paso 2, imagen 1 de 1
    • Remove the SIM card tray assembly from the HTC One M8.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
  3. HTC One M8 Headphone Jack/Micro USB Board Replacement, MicroSD Card: paso 3, imagen 1 de 2 HTC One M8 Headphone Jack/Micro USB Board Replacement, MicroSD Card: paso 3, imagen 2 de 2
    • Insert a SIM card eject tool or a paperclip into the small hole in the microSD card tray, located on the upper right hand side of the phone.
  4. HTC One M8 Headphone Jack/Micro USB Board Replacement: paso 4, imagen 1 de 1
    • Remove the microSD card tray assembly from the HTC One M8.
    • When reinserting the microSD card, ensure that it is in the proper orientation relative to the tray.
  5. HTC One M8 Headphone Jack/Micro USB Board Replacement, Rear Case: paso 5, imagen 1 de 2 HTC One M8 Headphone Jack/Micro USB Board Replacement, Rear Case: paso 5, imagen 2 de 2
    • Use an iOpener or heat gun to loosen the adhesive on the upper and lower speaker grilles.
    • Refer to the iOpener guide for info on how to use the iOpener.
  6. HTC One M8 Headphone Jack/Micro USB Board Replacement: paso 6, imagen 1 de 3 HTC One M8 Headphone Jack/Micro USB Board Replacement: paso 6, imagen 2 de 3 HTC One M8 Headphone Jack/Micro USB Board Replacement: paso 6, imagen 3 de 3
    • Use a plastic opening tool to gently peel up the lower speaker grille.
    • The adhesive is messy, and can be removed using Goo-gone.
  7. HTC One M8 Headphone Jack/Micro USB Board Replacement: paso 7, imagen 1 de 2 HTC One M8 Headphone Jack/Micro USB Board Replacement: paso 7, imagen 2 de 2
    • Use a plastic opening tool to gently peel up the upper speaker grille.
  8. HTC One M8 Headphone Jack/Micro USB Board Replacement: paso 8, imagen 1 de 1
    • Remove the two silver 3 mm Phillips #00 screws from the top.
    • Remove the four black 4 mm T5 Torx screws from the bottom.
  9. HTC One M8 Headphone Jack/Micro USB Board Replacement: paso 9, imagen 1 de 3 HTC One M8 Headphone Jack/Micro USB Board Replacement: paso 9, imagen 2 de 3 HTC One M8 Headphone Jack/Micro USB Board Replacement: paso 9, imagen 3 de 3
    • Work your way around the perimeter of the phone with a spudger and plastic opening picks to free the clips that secure the rear case to the display assembly.
    • A metal spudger is pictured, but it is best to use a nylon spudger to prevent marring the device.
    • Be careful not to lose the power button: it sits loosely in the top of the lower chassis.
    • Significant force may be required to pry the casing apart.
  10. HTC One M8 Headphone Jack/Micro USB Board Replacement, Headphone Jack/Micro USB Board: paso 10, imagen 1 de 2 HTC One M8 Headphone Jack/Micro USB Board Replacement, Headphone Jack/Micro USB Board: paso 10, imagen 2 de 2
    • Remove the two silver 2mm Phillips #00 screws securing the battery connector to the motherboard.
    • Use a plastic opening tool to gently pry up the battery connector.
  11. HTC One M8 Headphone Jack/Micro USB Board Replacement: paso 11, imagen 1 de 3 HTC One M8 Headphone Jack/Micro USB Board Replacement: paso 11, imagen 2 de 3 HTC One M8 Headphone Jack/Micro USB Board Replacement: paso 11, imagen 3 de 3
    • Use a spudger to disconnect the two ZIF connectors.
    • Use the flat end of a spudger to disconnect the black antenna cable.
    • Use a set of tweezers to pull the two ribbon cables free of the ZIF connectors.
  12. HTC One M8 Headphone Jack/Micro USB Board Replacement: paso 12, imagen 1 de 3 HTC One M8 Headphone Jack/Micro USB Board Replacement: paso 12, imagen 2 de 3 HTC One M8 Headphone Jack/Micro USB Board Replacement: paso 12, imagen 3 de 3
    • Remove the single silver 4mm T5 Torx screw securing the headphone jack/micro USB board.
    • You may need to gently bend the small ribbon cable out of the way to get to the screw.
    • Use a pair of tweezers or a plastic opening tool to gently pry the headphone jack/micro USB board up and out of the phone.
Conclusión
71 personas más completaron esta guía.
Michael Gonzalez
Miembro Desde 04/14/15
4,430 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 5-9, Maness Spring 2015 Miembro de Cal Poly, Team 5-9, Maness Spring 2015
CPSU-MANESS-S15S5G9
4 Miembros
18 Guías creadas
23 comentarios
Worked for me - though looks like I will need to reopen as there is a problem with the wifi antenna & bluetooth connection is weak
Timothy Cockle - Contestar
i dont have one from sprint or horizon.. Which one do i buy?
Vik De Brandt - Contestar
Anybody want a new battery and charging port? Ok, only slightly used as the repair failed. When I got everything back together the LCD/backlight won't come on. I could charge the battery fine and you can feel the device responding to touch so the sensors in the display are working, but the screen will not light up what so ever. Now after a 3rd attempt to disassemble and reassemble searching in vane to find a lose connection there's a new problem, when I connect the battery lead to the terminals the phone vibrates. The only way to make the phone stop vibrating is to disconnect the battery. I can only assume this phone is now toast so it would be a shame to toss the 2 new parts...
spepperdine - Contestar
How much? I'm having issues with the charging port not connecting to the micro used well
Jeremy Hunton -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 20
Ultimos 30 días: 32
Todo El Tiempo: 67,111
