Introducción
Be cautious about the ribbon cable
First remove the back cover of your phone to expose the battery.
  • First remove the back cover of your phone to expose the battery.
Agregar Comentario
Turn the phone over and remove the battery by using your thumb to push forward on the battery and then lift it.
  • Turn the phone over and remove the battery by using your thumb to push forward on the battery and then lift it.
Agregar Comentario
Take the battery out When reassembling, make sure that the battery contacts match up.
  • Take the battery out
  • When reassembling, make sure that the battery contacts match up.
Agregar Comentario
Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone
  • Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone
Agregar Comentario
Guía de regalos para el día del padre
Honremos a más que nuestros padres—celebremos a todos los mentores que nos enseñaron a reparar.
Honremos a aquellos que nos enseñaron a reparar.
Remove the two 4.3mm #00 Phillips screws that secure the back panel to the rest of the phone
  • Remove the two 4.3mm #00 Phillips screws that secure the back panel to the rest of the phone
Agregar Comentario
Use the plastic opening tool to pry the clips off Insert the plastic opening tool along the seams at different points to it pry up This may require a bit of force. The USB port cover may fall off in this step.
  • Use the plastic opening tool to pry the clips off
  • Insert the plastic opening tool along the seams at different points to it pry up
  • This may require a bit of force. The USB port cover may fall off in this step.
Agregar Comentario
Remove the one 3.3mm #00 screw. Remove the one 3.3mm #00 screw.
  • Remove the one 3.3mm #00 screw.
Agregar Comentario
Use your finger or the plastic opening tool to unclip the board. Be aware of the ribbon cable connected to the motherboard inside the phone.
  • Use your finger or the plastic opening tool to unclip the board.
  • Be aware of the ribbon cable connected to the motherboard inside the phone.
Agregar Comentario
Peel off the yellow piece of tape from the phone Peel off the yellow piece of tape from the phone
  • Peel off the yellow piece of tape from the phone
Agregar Comentario
First flip up the retaining flap with your fingernail or a plastic opening tool. Pull on the ribbon cable gently with your fingers Pull on the ribbon cable gently with your fingers
  • First flip up the retaining flap with your fingernail or a plastic opening tool.
  • Pull on the ribbon cable gently with your fingers
Agregar Comentario
Split apart the motherboard and front panel. Remove the other yellow piece of tape off of the end of the ribbon cable. Split apart the motherboard and front panel. Remove the other yellow piece of tape off of the end of the ribbon cable.
  • Split apart the motherboard and front panel. Remove the other yellow piece of tape off of the end of the ribbon cable.
Agregar Comentario
Gently pull on the ribbon cable to separate the motherboard. Gently pull on the ribbon cable to separate the motherboard.
  • Gently pull on the ribbon cable to separate the motherboard.
Agregar Comentario
Conclusión
Equipo
Cal Poly, Team 20-29, Maness Fall 2011 Miembro de Cal Poly, Team 20-29, Maness Fall 2011
CPSU-MANESS-F11S20G29
4 Miembros
9 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 1,014
