Saltar al contenido principal
HTC Maple 100 Keyboard Replacement
Qué necesitas
  1. HTC Maple 100 Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • First remove the back cover of your phone to expose the battery.
  2. HTC Maple 100 Keyboard Replacement: paso 2, imagen 1 de 1
    • Turn the phone over.
    • Push forward on the battery with your thumb.
  3. HTC Maple 100 Keyboard Replacement: paso 3, imagen 1 de 2 HTC Maple 100 Keyboard Replacement: paso 3, imagen 2 de 2
    • Take the battery out by lifting it upwards.
    • When reassembling, make sure that the battery contacts match up.
  4. HTC Maple 100 Keyboard Replacement, Back Panel: paso 4, imagen 1 de 2 HTC Maple 100 Keyboard Replacement, Back Panel: paso 4, imagen 2 de 2
    • Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone.
  5. HTC Maple 100 Keyboard Replacement: paso 5, imagen 1 de 1
    • Remove the two 4.3mm Phillips #00 screws that secure the back panel to the rest of the phone.
  6. HTC Maple 100 Keyboard Replacement: paso 6, imagen 1 de 3 HTC Maple 100 Keyboard Replacement: paso 6, imagen 2 de 3 HTC Maple 100 Keyboard Replacement: paso 6, imagen 3 de 3
    • Insert the plastic opening tool along the seams at different points to it pry the clips off.
    • This may require a bit of force. The USB port cover may fall off in this step.
  7. HTC Maple 100 Keyboard Replacement, Motherboard: paso 7, imagen 1 de 2 HTC Maple 100 Keyboard Replacement, Motherboard: paso 7, imagen 2 de 2
    • Remove the one 3.3mm Phillips #00 screw.
  8. HTC Maple 100 Keyboard Replacement: paso 8, imagen 1 de 2 HTC Maple 100 Keyboard Replacement: paso 8, imagen 2 de 2
    • Use your finger or the plastic opening tool to unclip the board.
    • Be aware of the ribbon cable connected to the motherboard inside the phone.
  9. HTC Maple 100 Keyboard Replacement: paso 9, imagen 1 de 2 HTC Maple 100 Keyboard Replacement: paso 9, imagen 2 de 2
    • Peel off the yellow piece of tape from the phone.
  10. HTC Maple 100 Keyboard Replacement: paso 10, imagen 1 de 3 HTC Maple 100 Keyboard Replacement: paso 10, imagen 2 de 3 HTC Maple 100 Keyboard Replacement: paso 10, imagen 3 de 3
    • Flip up the retaining flap with your fingernail or a plastic opening tool.
    • Pull on the ribbon cable gently with your fingers.
  11. HTC Maple 100 Keyboard Replacement: paso 11, imagen 1 de 2 HTC Maple 100 Keyboard Replacement: paso 11, imagen 2 de 2
    • Split apart the motherboard and front panel.
    • Remove the other yellow piece of tape off of the end of the ribbon cable.
  12. HTC Maple 100 Keyboard Replacement: paso 12, imagen 1 de 2 HTC Maple 100 Keyboard Replacement: paso 12, imagen 2 de 2
    • Gently pull on the ribbon cable to separate the motherboard.
  13. HTC Maple 100 Keyboard Replacement, Trackball: paso 13, imagen 1 de 3 HTC Maple 100 Keyboard Replacement, Trackball: paso 13, imagen 2 de 3 HTC Maple 100 Keyboard Replacement, Trackball: paso 13, imagen 3 de 3
    • Using your fingers, gently pull the trackball out.
  14. HTC Maple 100 Keyboard Replacement, Keyboard: paso 14, imagen 1 de 2 HTC Maple 100 Keyboard Replacement, Keyboard: paso 14, imagen 2 de 2
    • Remove the four 1.9 mm Phillips #00 screws.
  15. HTC Maple 100 Keyboard Replacement: paso 15, imagen 1 de 1
    • Peel back the tape gently.
  16. HTC Maple 100 Keyboard Replacement: paso 16, imagen 1 de 1
    • Remove the board gently.
  17. HTC Maple 100 Keyboard Replacement: paso 17, imagen 1 de 2 HTC Maple 100 Keyboard Replacement: paso 17, imagen 2 de 2
    • Remove the keys carefully.
Conclusión
Nick
Miembro Desde 10/28/11
6 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 20-29, Maness Fall 2011 Miembro de Cal Poly, Team 20-29, Maness Fall 2011
CPSU-MANESS-F11S20G29
4 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 1,421
