Introducción
A part that might fail after you drop your HTC Magic is the speaker. Here's how to replace it. You will need Torx T6 & T5 drivers , a screwdriver, & a iPod opening tool(s).
Partes
No se requieren partes.
Open the phone by removing it's backcover (battery door) and the battery. REMEMBER to remove the simcard and microSD card. If you do not they'll be damaged when you remove them at a later stage. REMEMBER to remove the simcard and microSD card. If you do not they'll be damaged when you remove them at a later stage.
  • Open the phone by removing it's backcover (battery door) and the battery.
  • REMEMBER to remove the simcard and microSD card. If you do not they'll be damaged when you remove them at a later stage.
Agregar Comentario
Unscrew the six screws with a Torx T5 screwdriver.
  • Unscrew the six screws with a Torx T5 screwdriver.
Agregar Comentario
Guía de regalos para el día del padre
Honremos a más que nuestros padres—celebremos a todos los mentores que nos enseñaron a reparar.
Honremos a aquellos que nos enseñaron a reparar.
Remove the antenna (use the little gap at the top ). Remove the antenna (use the little gap at the top ).
  • Remove the antenna (use the little gap at the top ).
Agregar Comentario
  • Use the iPod opening tools (or your fingernails) to remove the hosuing by running along the seam bit by bit. It's easiest to start somewhere in the middle, then work your way across the top.
  • The housing is held by plastic clips, so be careful since you don't want to break these.
  • Carefully lift the front housing from the back.
Agregar Comentario
The rear housing should look like the picture on the left. The speaker part is at the top. Use a small bit (like a paperclip) to lift the speaker out of it's socket. It's glued in it's place, so you may need to use a bit of force.
  • The rear housing should look like the picture on the left. The speaker part is at the top.
  • Use a small bit (like a paperclip) to lift the speaker out of it's socket. It's glued in it's place, so you may need to use a bit of force.
    • Be sure not to touch any part of the speaker except the black plastic parts.
Agregar Comentario
Conclusión
LucasJV
Miembro Desde 18/05/10
645 Reputación
3 Guías creadas
Equipo
Verheij.co Miembro de Verheij.co
Business
1 Miembro
3 Guías creadas
Where can I buy a speaker's set for the HTC Magic, please?
Miguel Ponce - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 2
Todo El Tiempo: 10,535
