Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
  • Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
  • Remove both the battery and the SD card (Press SD card in to release)
  • Locate and remove the four Torx screws highlighted in the photo, with the phone laying face down on your work space.
Agregar Comentario
Carefully pry the inside back cover from the device using an appropriate size plastic opening tool or small flathead screwdriver.
  • Carefully pry the inside back cover from the device using an appropriate size plastic opening tool or small flathead screwdriver.
  • Insert the flat end between the back and front enclosure, working your way around the rim.
Agregar Comentario
Gently  depress and release the small plastic tabs around the rim in the front enclosure, highlighted here.
  • Gently depress and release the small plastic tabs around the rim in the front enclosure, highlighted here.
  • It is best to start with the tab found on the top center of the phone, as it is easiest to locate.
Agregar Comentario
Carefully separate the front and back enclosures once all of the clips have been disengaged. Be sure to not separate too quickly or you risk breaking an attached tab.
  • Carefully separate the front and back enclosures once all of the clips have been disengaged.
  • Be sure to not separate too quickly or you risk breaking an attached tab.
Agregar Comentario
Release the two ribbon cables using a plastic opening tool. Gently pry up the pop connectors used to attach the ribbon cables to the motherboard.
  • Release the two ribbon cables using a plastic opening tool.
  • Gently pry up the pop connectors used to attach the ribbon cables to the motherboard.
Agregar Comentario
Remove the two screws located at the bottom left and right of the motherboard using a small Phillips screwdriver. Remove the two screws located at the bottom left and right of the motherboard using a small Phillips screwdriver.
  • Remove the two screws located at the bottom left and right of the motherboard using a small Phillips screwdriver.
Agregar Comentario
Gently lift the motherboard out of the front enclosure once the screws are removed. Gently lift the motherboard out of the front enclosure once the screws are removed.
  • Gently lift the motherboard out of the front enclosure once the screws are removed.
Agregar Comentario
At this point it is a good idea to remove the track ball and enclosure to prevent accidental loss. To remove the trackball, turn the phone over into your cupped hand and the trackball will fall out. To remove the trackball, turn the phone over into your cupped hand and the trackball will fall out.
  • At this point it is a good idea to remove the track ball and enclosure to prevent accidental loss.
  • To remove the trackball, turn the phone over into your cupped hand and the trackball will fall out.
Agregar Comentario
Using an plastic opening tool, gently pry out the LCD screen from the left side of the enclosure as illustrated. You many need to gently wiggle the screen out or continue using the plastic opening tool until released. You many need to gently wiggle the screen out or continue using the plastic opening tool until released.
  • Using an plastic opening tool, gently pry out the LCD screen from the left side of the enclosure as illustrated.
  • You many need to gently wiggle the screen out or continue using the plastic opening tool until released.
Agregar Comentario
Conclusión
Equipo
Cal Poly, Team 3-26, Amido Winter 2012 Miembro de Cal Poly, Team 3-26, Amido Winter 2012
CPSU-AMIDO-W12S3G26
5 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 1,756
