Introducción
This guide will help you get to the speaker, in case it needs to be replaced
Carefully pull the rear cover from the back of the phone.
  • Carefully pull the rear cover from the back of the phone.
  • Place a finger beneath the small lip on the left side of the battery.
Agregar Comentario
Lay the phone down on it's screen. Lift up on the lip and pull the battery from the phone.
  • Lay the phone down on it's screen.
  • Lift up on the lip and pull the battery from the phone.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the four black 3.5mm T5 screws from the back of the phone. Remove the four black 3.5mm T5 screws from the back of the phone.
  • Remove the four black 3.5mm T5 screws from the back of the phone.
Agregar Comentario
Insert the flat end of a spudger between the midframe and the display. Slide the spudger along the seam between the frame and the display.
  • Insert the flat end of a spudger between the midframe and the display.
  • Slide the spudger along the seam between the frame and the display.
  • Using the spudger for leverage, carefully pry the midframe away from the display assembly.
    • This process will take some effort. Continue to pry slowly and carefully until the frame begins to detach.
  • As it releases, pull the midframe away from the phone.
  • The volume control tab may fall off during removal. It can be easily reattached.
Agregar Comentario
With the chassis removed, set down the phone and locate the speaker on the inside of the housing.
  • With the chassis removed, set down the phone and locate the speaker on the inside of the housing.
  • The speaker should be easily popped out of place with a small amount of force
Agregar Comentario
Congratulations! The speaker is now removed and can be replaced or repaired.
  • Congratulations! The speaker is now removed and can be replaced or repaired.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 24-55, Amido Spring 2011 Miembro de Cal Poly, Team 24-55, Amido Spring 2011
CPSU-AMIDO-S11S24G55
5 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 2
Todo El Tiempo: 6,721
