Introducción
This guide will assist you in removing the motherboard and rigid flex board in the HTC HD2.
Carefully pull the rear cover from the back of the phone.
  • Carefully pull the rear cover from the back of the phone.
  • Place a finger beneath the small lip on the left side of the battery.
Agregar Comentario
Lay the phone down on it's screen. Lift up on the lip and pull the battery from the phone.
  • Lay the phone down on it's screen.
  • Lift up on the lip and pull the battery from the phone.
Agregar Comentario
Remove the four black 3.5mm T5 screws from the back of the phone. Remove the four black 3.5mm T5 screws from the back of the phone.
  • Remove the four black 3.5mm T5 screws from the back of the phone.
Agregar Comentario
Insert the flat end of a spudger between the midframe and the display. Slide the spudger along the seam between the frame and the display.
  • Insert the flat end of a spudger between the midframe and the display.
  • Slide the spudger along the seam between the frame and the display.
  • Using the spudger for leverage, carefully pry the midframe away from the display assembly.
    • This process will take some effort. Continue to pry slowly and carefully until the frame begins to detach.
  • As it releases, pull the midframe away from the phone.
  • The volume control tab may fall off during removal. It can be easily reattached.
Agregar Comentario
Set the phone down on its screen. Using tweezers, unplug the small vibrator connector from its socket on the motherboard.
  • Set the phone down on its screen.
  • Using tweezers, unplug the small vibrator connector from its socket on the motherboard.
Agregar Comentario
Pull the vibrator motor from the phone.
  • Pull the vibrator motor from the phone.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Disconnect the small speaker cable from its socket on the motherboard. Remove the earpiece speaker from the phone. Remove the earpiece speaker from the phone.
  • Disconnect the small speaker cable from its socket on the motherboard.
  • Remove the earpiece speaker from the phone.
Agregar Comentario
Remove five T5 Torx screws from the motherboard. Remove five T5 Torx screws from the motherboard.
  • Remove five T5 Torx screws from the motherboard.
Agregar Comentario
Disconnect the flash cable from its socket at the bottom of the motherboard. Carefully pull the flash cable from its slot in the side of the phone. Carefully pull the flash cable from its slot in the side of the phone.
  • Disconnect the flash cable from its socket at the bottom of the motherboard.
  • Carefully pull the flash cable from its slot in the side of the phone.
Agregar Comentario
Pull the camera flash and cover off of the board. You may need to peel back the sticker that sits behind the battery. Work carefully. Excessive force can damage the camera or motherboard.
  • Pull the camera flash and cover off of the board.
    • You may need to peel back the sticker that sits behind the battery.
  • Work carefully. Excessive force can damage the camera or motherboard.
Agregar Comentario
Now locate the coaxial bluetooth cable that connects the top and bottom boards of the phone. Use tweezers to pop both ends of the cable from the boards and remove it completely. Use tweezers to pop both ends of the cable from the boards and remove it completely.
  • Now locate the coaxial bluetooth cable that connects the top and bottom boards of the phone.
  • Use tweezers to pop both ends of the cable from the boards and remove it completely.
Agregar Comentario
Now find the AP FPC, one of the smallest connectors on the bottom board. Pop the small black tab up using tweezers, then unplug the cable. Pop the small black tab up using tweezers, then unplug the cable.
  • Now find the AP FPC, one of the smallest connectors on the bottom board.
  • Pop the small black tab up using tweezers, then unplug the cable.
Hai i loos a kyepad one of the smallest connectors on the bottom board.
can u arrange the connector i need it pls. reply soon
Fazil Khan - Contestar
I had htc td2 mobile i loos my kyepad strip and one of the smallest connectors on the bottom board.
Can u have a connector if u have means reply my mail it i need it
my mail ID is fazilkhan375@gmail.com
reply soon
thanks and regards : FAZIL KHAN
This step is pretty much irreversible, so do not do this unless you absolutely have to. Remember peeling back part of that big sticker in the middle? Now you get to take it all the way off. This may take some time, and the use of the tweezers, but keep at it until the whole sticker is off.
  • This step is pretty much irreversible, so do not do this unless you absolutely have to.
  • Remember peeling back part of that big sticker in the middle? Now you get to take it all the way off.
  • This may take some time, and the use of the tweezers, but keep at it until the whole sticker is off.
Agregar Comentario
Now find the GPS board in the upper left hand corner of the phone.
  • Now find the GPS board in the upper left hand corner of the phone.
  • Disconnect the white cable from its socket on the motherboard.
  • The cable does not need to be unplugged from the main bottom board.
  • This cable is connected to the underside of the bottom board. If it is detached, be sure to reconnect it before reassembling the phone.
Agregar Comentario
If this step does not progress easily, check to see that there are no screws still holding the board in place. With the cable removed, pop the GPS board out of the phone using tweezers. With the cable removed, pop the GPS board out of the phone using tweezers.
  • If this step does not progress easily, check to see that there are no screws still holding the board in place.
  • With the cable removed, pop the GPS board out of the phone using tweezers.
Agregar Comentario
Using a spudger, begin to pry the copper colored board in the middle away from the phone to loosen it. Also pry the small piece that runs under where the volume selector is on the full phone. Also pry the small piece that runs under where the volume selector is on the full phone.
  • Using a spudger, begin to pry the copper colored board in the middle away from the phone to loosen it.
  • Also pry the small piece that runs under where the volume selector is on the full phone.
Agregar Comentario
There is a connecter cable under the main board, so do not pull it all the way off right away. Gently pop both the top and bottom boards off of the phone, and turn them over to the left Gently pop both the top and bottom boards off of the phone, and turn them over to the left
  • There is a connecter cable under the main board, so do not pull it all the way off right away.
  • Gently pop both the top and bottom boards off of the phone, and turn them over to the left
Agregar Comentario
With the back of the main board exposed, flip up the little brown lever at the end of the connector and unplug the final cable that connects it to the main board. With the back of the main board exposed, flip up the little brown lever at the end of the connector and unplug the final cable that connects it to the main board.
  • With the back of the main board exposed, flip up the little brown lever at the end of the connector and unplug the final cable that connects it to the main board.
Agregar Comentario
Conclusión
4 personas más completaron esta guía.
Equipo
Cal Poly, Team 24-55, Amido Spring 2011 Miembro de Cal Poly, Team 24-55, Amido Spring 2011
CPSU-AMIDO-S11S24G55
5 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 5
Últimos 30 Días: 13
Todo El Tiempo: 14,918
