Introducción
Use this guide to replace a defective dual LED flash assembly.
Gently insert an iPod opening tool between the rear panel and the inner rear frame near the headphone jack.
  • Gently insert an iPod opening tool between the rear panel and the inner rear frame near the headphone jack.
  • Use your iPod opening tool to pry up the rear case around the perimeter of the Evo.
Agregar Comentario
Lift the rear panel off of the inner rear frame.
  • Lift the rear panel off of the inner rear frame.
Agregar Comentario
Using the tip of your finger, lift the battery from the end closest to the camera. Remove the battery from the rear inner frame.
  • Using the tip of your finger, lift the battery from the end closest to the camera.
  • Remove the battery from the rear inner frame.
Agregar Comentario
Use the flat end of a spudger to pry up the red MicroSD retainer attached to the inner frame.
  • Use the flat end of a spudger to pry up the red MicroSD retainer attached to the inner frame.
  • The retainer will move about 1 mm and stop. Do not attempt to completely remove the MicroSD card retainer.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Use a pair of tweezers to carefully pull the MicroSD card out of its slot in the inner rear frame.
  • Use a pair of tweezers to carefully pull the MicroSD card out of its slot in the inner rear frame.
Agregar Comentario
Remove six T5 Torx screws securing the rear inner frame to the inner case.
  • Remove six T5 Torx screws securing the rear inner frame to the inner case.
Agregar Comentario
Gently insert an iPod opening tool between the rear inner frame and its plastic surround near the Micro HDMI port.
  • Gently insert an iPod opening tool between the rear inner frame and its plastic surround near the Micro HDMI port.
  • Carefully pry the top edge of the rear inner frame away from the front surround of the Evo.
Agregar Comentario
Insert the iPod opening tool between the rear inner frame and its plastic surround and pry up at several points along the left edge of the Evo. Insert the iPod opening tool between the rear inner frame and its plastic surround and pry up at several points along the left edge of the Evo.
  • Insert the iPod opening tool between the rear inner frame and its plastic surround and pry up at several points along the left edge of the Evo.
Agregar Comentario
Continue the prying procedure, now focusing on detaching the plastic surround from the bottom of the Evo. Pry up the rear inner frame along the right edge using the method described in previous steps. Eventually work around the entire perimeter of the rear inner frame until it is lifted slightly from the inner case.
  • Continue the prying procedure, now focusing on detaching the plastic surround from the bottom of the Evo.
  • Pry up the rear inner frame along the right edge using the method described in previous steps.
  • Eventually work around the entire perimeter of the rear inner frame until it is lifted slightly from the inner case.
Agregar Comentario
Remove the rear inner frame from the rest of the Evo.
  • Remove the rear inner frame from the rest of the Evo.
Agregar Comentario
Remove the two Phillips screws securing the dual LED flash assembly to the rear inner frame.
  • Remove the two Phillips screws securing the dual LED flash assembly to the rear inner frame.
Agregar Comentario
Use an iPod opening tool to pry the dual LED flash assembly off the posts securing it to the rear inner frame.
  • Use an iPod opening tool to pry the dual LED flash assembly off the posts securing it to the rear inner frame.
  • Remove the dual LED flash unit from the rear inner frame.
Agregar Comentario
Conclusión
5 personas más completaron esta guía.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 15,323
