Saltar al contenido principal
HTC Evo 4G Battery Replacement
Qué necesitas
  1. HTC Evo 4G Battery Replacement, Rear Panel: paso 1, imagen 1 de 1
    • Gently insert an iPod opening tool between the rear panel and the inner rear frame near the headphone jack.
    • Use your iPod opening tool to pry up the rear case around the perimeter of the Evo.
  2. HTC Evo 4G Battery Replacement: paso 2, imagen 1 de 1
    • Lift the rear panel off of the inner rear frame.
  3. HTC Evo 4G Battery Replacement, Battery: paso 3, imagen 1 de 2 HTC Evo 4G Battery Replacement, Battery: paso 3, imagen 2 de 2
    • Using the tip of your finger, lift the battery from the end closest to the camera.
    • Remove the battery from the rear inner frame.
Conclusión
10 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 23,000
