Introducción
Use this guide to remove the rear inner frame and expose internal components.
Press your thumbnail into the slot between the rear panel and the front case located in the bottom of the phone. Useful tip: a penny or dime works in a pinch if you can't use your thumbnail. Gently pry the rear panel up and away from the phone. You may need to slide your thumb up the crack to separate the rear panel from the front case.
  • Press your thumbnail into the slot between the rear panel and the front case located in the bottom of the phone.
    • Useful tip: a penny or dime works in a pinch if you can't use your thumbnail.
  • Gently pry the rear panel up and away from the phone. You may need to slide your thumb up the crack to separate the rear panel from the front case.
Agregar Comentario
Remove the rear panel from the phone.
  • Remove the rear panel from the phone.
Agregar Comentario
Insert a fingertip into the gap between the battery and the rear inner frame, located between the battery and the speaker. Slide the battery away from the speaker, widening the gap. Lift the top of the battery up and remove the battery from the rear inner frame. Lift the top of the battery up and remove the battery from the rear inner frame.
  • Insert a fingertip into the gap between the battery and the rear inner frame, located between the battery and the speaker. Slide the battery away from the speaker, widening the gap.
  • Lift the top of the battery up and remove the battery from the rear inner frame.
Agregar Comentario
Press the MicroSD card further into its slot until it clicks. Release the MicroSD card, and it will pop out slightly.
  • Press the MicroSD card further into its slot until it clicks.
  • Release the MicroSD card, and it will pop out slightly.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Pull the MicroSD card straight out of its slot. Pull the MicroSD card straight out of its slot.
  • Pull the MicroSD card straight out of its slot.
Agregar Comentario
Remove four T6 Torx screws securing the rear inner frame to the front case.
  • Remove four T6 Torx screws securing the rear inner frame to the front case.
Agregar Comentario
The rear inner frame is attached to the front case by nine plastic clips, marked here for reference.
  • The rear inner frame is attached to the front case by nine plastic clips, marked here for reference.
Agregar Comentario
Starting on the bottom of the phone, gently push in on the (red) rear inner frame behind each black clip with a small flathead screwdriver. Go slow and be gentle, you may have to go back and forth between each side several times to work the rear inner case free.
  • Starting on the bottom of the phone, gently push in on the (red) rear inner frame behind each black clip with a small flathead screwdriver.
  • Go slow and be gentle, you may have to go back and forth between each side several times to work the rear inner case free.
Agregar Comentario
Loosen the clips on the side next to the camera using the method described in the previous step. Loosen the clips on the side next to the camera using the method described in the previous step.
  • Loosen the clips on the side next to the camera using the method described in the previous step.
Agregar Comentario
Rotate the phone 180 degrees and loosen the three clips on the side by the speaker. Note that the middle clip on this side is smaller than the others. Rotate the phone 180 degrees and loosen the three clips on the side by the speaker. Note that the middle clip on this side is smaller than the others.
  • Rotate the phone 180 degrees and loosen the three clips on the side by the speaker. Note that the middle clip on this side is smaller than the others.
Agregar Comentario
Use the same technique to loosen the clip on the top of the phone. You may need to gently lift the bottom of the rear inner frame to free this clip. You may need to gently lift the bottom of the rear inner frame to free this clip.
  • Use the same technique to loosen the clip on the top of the phone.
  • You may need to gently lift the bottom of the rear inner frame to free this clip.
Agregar Comentario
Remove the rear inner frame. Remove the rear inner frame.
  • Remove the rear inner frame.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Andrew Optimus Goldberg
Miembro Desde 17/10/09
371,713 Reputación
1,284 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
114 Miembros
5,895 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 820
