Qué necesitas
While sliding the silver release tab up, simultaneously lift the cover up from the left side.
Remove the four silver screws using the T5 Torx Screwdriver (T5 x .25 in).
Now that the back cover is removed, use the #00 Philips x .17 screwdriver to remove the small screw to the left of the SD card slot.
Now that the front cover is removed we can detach the screen
Remove the ribbon connector by pulling gently on the silver top. It will snap off the mother board.
Una persona más ha completado esta guía.
