Introducción
This step-by-step guide illustrates how to remove and replace the back case of a Pocket PC.
Partes
No se requieren partes.
Slide the silver release tab up and simultaneously lift the cover up from the left side.
  • Slide the silver release tab up and simultaneously lift the cover up from the left side.
Agregar Comentario
Push the tab from left to right to remove the cover.
  • Push the tab from left to right to remove the cover.
Agregar Comentario
Now lift the battery up and away from the device to remove it.
  • Now lift the battery up and away from the device to remove it.
Agregar Comentario
Remove the four silver screws (T5 x .25 in).
  • Remove the four silver screws (T5 x .25 in).
Agregar Comentario
Remove the single black screw (T5 x .125 in) beneath the HP sticker.
  • Remove the single black screw (T5 x .125 in) beneath the HP sticker.
Agregar Comentario
Next, use your plastic removal tool to separate the gray back from the black center piece. For better results, start the separation at the corner piece.
  • Next, use your plastic removal tool to separate the gray back from the black center piece.
  • For better results, start the separation at the corner piece.
Agregar Comentario
Remove the back case.
  • Remove the back case.
Agregar Comentario
Conclusión
3 personas más completaron esta guía.
John Pagliero
Miembro Desde 27/01/11
886 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 3-39, Regan Winter 2011 Miembro de Cal Poly, Team 3-39, Regan Winter 2011
CPSU-REGAN-W11S3G39
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 666
