Partes
No se requieren partes.
Flip the HP iPAQ HW6515 over with the screen facing down. Take the back cover off by pressing on the small silver button while pulling back then up on the case. Place the back of the case aside for now.
  • Flip the HP iPAQ HW6515 over with the screen facing down.
  • Take the back cover off by pressing on the small silver button while pulling back then up on the case.
  • Place the back of the case aside for now.
Agregar Comentario
Remove the battery by pulling up on the black tab.
  • Remove the battery by pulling up on the black tab.
Agregar Comentario
Unscrew the four screws using the T6 hexagonal star screwdriver. Unscrew the middle screw using the Phillips 00 screwdriver. "Warranty VOID if broken" sticker might be covering the middle screw, if this is the case, peel it off to reveal the screw.
  • Unscrew the four screws using the T6 hexagonal star screwdriver.
  • Unscrew the middle screw using the Phillips 00 screwdriver.
  • "Warranty VOID if broken" sticker might be covering the middle screw, if this is the case, peel it off to reveal the screw.
Agregar Comentario
Use the plastic opening tool to pry apart the covers along the bottom of the phone. Slide the plastic opening tool along the seam until the two halves of the case separate. Slide the plastic opening tool along the seam until the two halves of the case separate.
  • Use the plastic opening tool to pry apart the covers along the bottom of the phone.
  • Slide the plastic opening tool along the seam until the two halves of the case separate.
Agregar Comentario
Unplug the sensor wire that connects the two halves of the case before pulling the two halves apart. Not doing so will damage the sensor wire. Unplug the sensor wire that connects the two halves of the case before pulling the two halves apart. Not doing so will damage the sensor wire.
  • Unplug the sensor wire that connects the two halves of the case before pulling the two halves apart. Not doing so will damage the sensor wire.
Agregar Comentario
Gently pull off the black rubber square covering the LED light. The LED is now exposed. Wedge the plastic opening tool under the LED to pop it out and expose its wire.
  • Gently pull off the black rubber square covering the LED light.
  • The LED is now exposed.
  • Wedge the plastic opening tool under the LED to pop it out and expose its wire.
  • Using your index finger and thumb, unplug the wire from the phone and remove the LED.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Steven Vo
Miembro Desde 02/04/12
33 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 15-17, Forte Spring 2012 Miembro de Cal Poly, Team 15-17, Forte Spring 2012
CPSU-FORTE-S12S15G17
4 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 1,037
