Introducción
The purpose of this guide is to instruct the reader on how to replace the faceplates of their HP iPAQ H2200 device.
Partes
No se requieren partes.
Press and slide the battery cover tab to remove battery cover.
  • Press and slide the battery cover tab to remove battery cover.
Agregar Comentario
Pull on the black tab to lift the battery out of the battery compartment. Pull on the black tab to lift the battery out of the battery compartment.
  • Pull on the black tab to lift the battery out of the battery compartment.
Agregar Comentario
Remove the stylus by sliding it out of the slot.
  • Remove the stylus by sliding it out of the slot.
Agregar Comentario
Remove the CF card by sliding it out of the slot at the top of the device.
  • Remove the CF card by sliding it out of the slot at the top of the device.
Agregar Comentario
Press down and push the black side strips toward the top of the device to remove them.
  • Press down and push the black side strips toward the top of the device to remove them.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Using the T5 Torx screwdriver,  remove all six screws on the back and all screws on each side of the device. Using the T5 Torx screwdriver,  remove all six screws on the back and all screws on each side of the device. Using the T5 Torx screwdriver,  remove all six screws on the back and all screws on each side of the device.
  • Using the T5 Torx screwdriver, remove all six screws on the back and all screws on each side of the device.
Agregar Comentario
Remove the back faceplate by pushing and loosening the 4 side slots (2 on each side). Remove the back faceplate by pushing and loosening the 4 side slots (2 on each side).
  • Remove the back faceplate by pushing and loosening the 4 side slots (2 on each side).
Agregar Comentario
Open the LCD connector, where the orange strip attaches to the main board.
  • Open the LCD connector, where the orange strip attaches to the main board.
Agregar Comentario
Carefully remove the orange LCD strip from the connector.
  • Carefully remove the orange LCD strip from the connector.
Agregar Comentario
Unscrew the 2 screws located at each top corner of the main board.
  • Unscrew the 2 screws located at each top corner of the main board.
Agregar Comentario
Remove the main board by pushing outward on the two tabs located on each side near the bottom of the device.
  • Remove the main board by pushing outward on the two tabs located on each side near the bottom of the device.
Agregar Comentario
Unscrew the two bottom screws on LCD screen that were previously located under the main board.
  • Unscrew the two bottom screws on LCD screen that were previously located under the main board.
Agregar Comentario
Press on side tabs to loosen and remove the LCD screen. Press on side tabs to loosen and remove the LCD screen.
  • Press on side tabs to loosen and remove the LCD screen.
Agregar Comentario
Remove the faceplate by unscrewing the green screw located on the top right of the front faceplate.
  • Remove the faceplate by unscrewing the green screw located on the top right of the front faceplate.
Agregar Comentario
Conclusión
Tyler Andrews
Miembro Desde 13/01/10
191 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 4-12, Forte Winter 2010 Miembro de Cal Poly, Team 4-12, Forte Winter 2010
CPSU-FORTE-W10S4G12
3 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 3
Todo El Tiempo: 1,274
