Saltar al contenido principal
HP Spectre x360 13t-4000 Battery Replacement
Qué necesitas
  1. HP Spectre x360 13t-4000 Battery Replacement, Bottom Cover: paso 1, imagen 1 de 2 HP Spectre x360 13t-4000 Battery Replacement, Bottom Cover: paso 1, imagen 2 de 2
    • Turn off and unplug the laptop.
    • Flip over the laptop so that the bottom backplate is exposed.
  2. HP Spectre x360 13t-4000 Battery Replacement: paso 2, imagen 1 de 2 HP Spectre x360 13t-4000 Battery Replacement: paso 2, imagen 2 de 2
    • Use a T5 screwdriver to remove the six 3 mm screws that secure the backplate.
    • Use the same screwdriver to remove the two 7 mm screws.
  3. HP Spectre x360 13t-4000 Battery Replacement: paso 3, imagen 1 de 3 HP Spectre x360 13t-4000 Battery Replacement: paso 3, imagen 2 de 3 HP Spectre x360 13t-4000 Battery Replacement: paso 3, imagen 3 de 3
    • Insert an opening tool under the bottom cover at the screen hinges, and gently pry the cover free.
    • Carefully work your way around the cover's edges to pop it off completely.
  4. HP Spectre x360 13t-4000 Battery Replacement, Battery: paso 4, imagen 1 de 3 HP Spectre x360 13t-4000 Battery Replacement, Battery: paso 4, imagen 2 de 3 HP Spectre x360 13t-4000 Battery Replacement, Battery: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • With the backplate removed, remove the four 3 mm screws securing the battery with a Phillips #1 screwdriver.
    • With the screws removed, disconnect the 3 wires connected to the battery.
    • Tweezers may be needed to remove the wires.
Conclusión
4 personas más completaron esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 31
Todo El Tiempo: 11,565
