Shut the device off. Lift the top cover of the scanner. Carefully, pry the plastic frame surrounding the glass away from the printer hood using a plastic prying tool.
  • Shut the device off.
  • Lift the top cover of the scanner.
  • Carefully, pry the plastic frame surrounding the glass away from the printer hood using a plastic prying tool.
  • Pull the frame out.
Agregar Comentario
Unscrew the two screws that fasten the frame to the printer hood. Use a T10 screwdriver
  • Unscrew the two screws that fasten the frame to the printer hood. Use a T10 screwdriver
Agregar Comentario
Pushing the clip behind the cover piece in, pull the cover piece outwards. Pushing the clip behind the cover piece in, pull the cover piece outwards.
  • Pushing the clip behind the cover piece in, pull the cover piece outwards.
Agregar Comentario
Remove the two screws on the front of the printer with a T10 screwdriver. The first is inside the power button panel space and the second is across the printer slider.
  • Remove the two screws on the front of the printer with a T10 screwdriver.
    • The first is inside the power button panel space and the second is across the printer slider.
Agregar Comentario
Pull the circuit board from the power button panel space.
  • Pull the circuit board from the power button panel space.
  • Unplug the small ribbon cable from the circuit board.
Agregar Comentario
Pull the memory card reader's circuit board out of its slot. Detach the rainbow connector from the back of the circuit board.
  • Pull the memory card reader's circuit board out of its slot.
  • Detach the rainbow connector from the back of the circuit board.
Agregar Comentario
Press the clip directly behind the TouchSmart panel and pull the panel up. Disconnect the ribbon cable from the TouchSmart panel. This detaches the panel from the printer body.
  • Press the clip directly behind the TouchSmart panel and pull the panel up.
  • Disconnect the ribbon cable from the TouchSmart panel. This detaches the panel from the printer body.
  • Do not hesitate to use force to remove the TouchSmart panel.
Agregar Comentario
Grip the printer hood and pull upward.
  • Grip the printer hood and pull upward.
Agregar Comentario
Lift the scanning lid from the lower portion of the printer hood. Lift the scanning lid from the lower portion of the printer hood.
  • Lift the scanning lid from the lower portion of the printer hood.
Remove torx screw on bottom of assembly in corner near touchsmart screen space.
Jeff - Contestar
Leaving the ribbon connected, lift the sliding scanner off the track. Pull the ribbon cable out of the slot on the scanner circuit board.
  • Leaving the ribbon connected, lift the sliding scanner off the track.
  • Pull the ribbon cable out of the slot on the scanner circuit board.
  • Insert the scanning piece into the rolling track.
Agregar Comentario
Conclusión
To reassemble the sliding scan piece, follow these instructions in reverse order.
Renee Lamb
Miembro Desde 26/09/12
208 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 2-11, Propen Fall 2012 Miembro de Cal Poly, Team 2-11, Propen Fall 2012
CPSU-PROPEN-F12S2G11
4 Miembros
6 Guías creadas
Where can i buy the scaning piece? Im from Spain.
Bogdan Cosmin - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 2
Últimos 30 Días: 11
Todo El Tiempo: 1,209
