Partes
No se requieren partes.
Before disassembling your printer, be sure that the printer has been unplugged. Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
  • Before disassembling your printer, be sure that the printer has been unplugged.
  • Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
  • Remove the two T10 12mm Torx screws from the left side panel.
Agregar Comentario
Firmly pull the the back of the side panel until it separates from the body of the printer. Rotate the side panel upwards while pulling it towards yourself to remove the panel.
  • Firmly pull the the back of the side panel until it separates from the body of the printer.
  • Rotate the side panel upwards while pulling it towards yourself to remove the panel.
Agregar Comentario
Rotate the printer 90 degrees clockwise. Grasp the paper tray and rotate it down.
  • Rotate the printer 90 degrees clockwise.
  • Grasp the paper tray and rotate it down.
  • Insert your fingers into the slot in the printer door and pull to rotate the gate down.
Agregar Comentario
Rotate the printer 90 degrees clockwise. Remove the two T10 12 mm Torx screws.
  • Remove the two T10 12 mm Torx screws.
  • Grasp both sides of the side panel and pull it forward to remove the panel.
Agregar Comentario
Rotate the printer 90 degrees counter clockwise. Lift the scanner lid to expose the scanner glass.
  • Rotate the printer 90 degrees counter clockwise.
  • Lift the scanner lid to expose the scanner glass.
Agregar Comentario
  • Do not attempt to lift the top panel off the printer yet because it is still connected to the printer body by a cable.
Agregar Comentario
Rotate the printer 90 degrees counter clockwise. Inside the printer is a small white tab. Press it inward with a spudger until a pop is heard.
  • Inside the printer is a small white tab. Press it inward with a spudger until a pop is heard.
  • Remove the front panel by grasping its front and pulling away from the printer.
Agregar Comentario
Rotate the printer 90 degrees clockwise. Remove the cable connecting the top panel of the printer to the power button assembly.
  • Remove the cable connecting the top panel of the printer to the power button assembly.
Agregar Comentario
Carefully lift the top panel of the printer away from the printer body.
  • Carefully lift the top panel of the printer away from the printer body.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Set aside the top panel of the printer. Remove the two T10 12 mm Torx screws from the top front of the printer
  • Set aside the top panel of the printer.
  • Remove the two T10 12 mm Torx screws from the top front of the printer
Agregar Comentario
Rotate the Printer 90 degrees counter clockwise. Remove the scanner cable from the main circuit board.
  • Rotate the Printer 90 degrees counter clockwise.
  • Remove the scanner cable from the main circuit board.
  • Grasp the bottom of the cable and pull straight up. Do not wiggle it from side to side or twist it as this can damage the connection.
Agregar Comentario
  • Using both hands, lift the scanner tray from the body of the printer.
Agregar Comentario
Remove the power button circuit board from the support frame by pinching the left side, and pulling forward and to the left simultaneously. Push up on the tab holding the secondary control circuit board with the spudger and pull it forward to remove it.
  • Remove the power button circuit board from the support frame by pinching the left side, and pulling forward and to the left simultaneously.
  • Push up on the tab holding the secondary control circuit board with the spudger and pull it forward to remove it.
  • Be careful not to pull too hard on the cable connecting the power button control circuit board and the secondary control circuit board to the main circuit board
Agregar Comentario
Remove the two T10 12 mm Torx screws. Lift the support frame off of the printer body with both hands.
  • Lift the support frame off of the printer body with both hands.
Agregar Comentario
Remove the printer door and paper tray by putting them in the closed position and not laying flat then rotating them upwards lift the left side up.
  • Remove the printer door and paper tray by putting them in the closed position and not laying flat then rotating them upwards lift the left side up.
Agregar Comentario
Remove both of the ink cartridges by grabbing the front of the ink cartridge and pulling down. Make sure that the printer carriage is pushed all the way to the right.
  • Remove both of the ink cartridges by grabbing the front of the ink cartridge and pulling down.
  • Make sure that the printer carriage is pushed all the way to the right.
Agregar Comentario
Remove the  T10 6 mm Torx screw on the left side of the track assembly. Remove the T10 12 mm Torx screw on the left side of the track assembly.
  • Remove the T10 6 mm Torx screw on the left side of the track assembly.
  • Remove the T10 12 mm Torx screw on the left side of the track assembly.
Agregar Comentario
Gently push the ink cartridge carriage to the left side of the printer. Gently push the ink cartridge carriage to the left side of the printer.
  • Gently push the ink cartridge carriage to the left side of the printer.
Agregar Comentario
  • Remove the two T10 6 mm Torx screws.
Agregar Comentario
Rotate the printer 90 degrees counter clockwise. Remove the cable connecting the ink cartridge carriage to the main circuit board.
  • Remove the cable connecting the ink cartridge carriage to the main circuit board.
  • Pull straight up to free the cable from the main circuit board. Do not twist or wiggle the cable as doing so can damage it.
  • You may need to lift the carriage up with one hand in order to reach the cable with the free hand as shown.
Agregar Comentario
Carefully remove the connector holding the drive motor wires to the main circuit board.
  • Carefully remove the connector holding the drive motor wires to the main circuit board.
Agregar Comentario
Slide the ink cartridge carriage all the way to the right side of the printer. Using both hands, carefully lift the  ink cartridge track off of the main body of the printer.
  • Slide the ink cartridge carriage all the way to the right side of the printer.
  • Using both hands, carefully lift the ink cartridge track off of the main body of the printer.
Agregar Comentario
Set aside the printer body. Remove the two T10 4 mm Torx screws.
  • Set aside the printer body.
  • Remove the two T10 4 mm Torx screws.
Agregar Comentario
Grasp the bottom of the drive motor and rock it away from the center to release the tension in the cable. Use your fingers to unhook the cable from drive motor.
  • Grasp the bottom of the drive motor and rock it away from the center to release the tension in the cable.
  • Use your fingers to unhook the cable from drive motor.
Agregar Comentario
Remove the drive motor.
  • Remove the drive motor.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Jim
Miembro Desde 06/10/11
894 Reputación
10 Guías creadas
Equipo
Cal Poly, Team 20-30, Maness Fall 2011 Miembro de Cal Poly, Team 20-30, Maness Fall 2011
CPSU-MANESS-F11S20G30
4 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 5
Últimos 30 Días: 14
Todo El Tiempo: 3,806
