Saltar al contenido principal
HP Pavilion zd8000 Switch Cover Replacement
Qué necesitas
  1. HP Pavilion zd8000 Switch Cover Replacement, Battery: paso 1, imagen 1 de 1
    • Slide the battery release latch towards you.
  2. HP Pavilion zd8000 Switch Cover Replacement: paso 2, imagen 1 de 2 HP Pavilion zd8000 Switch Cover Replacement: paso 2, imagen 2 de 2
    • Pull up on the battery to remove it.
  3. HP Pavilion zd8000 Switch Cover Replacement, WiFi Card Cables: paso 3, imagen 1 de 2 HP Pavilion zd8000 Switch Cover Replacement, WiFi Card Cables: paso 3, imagen 2 de 2
    • Unscrew the four 8mm Philips screws marked with an icon resembling a stacks of discs.
    • Lift the cover from the right to remove it.
  4. HP Pavilion zd8000 Switch Cover Replacement: paso 4, imagen 1 de 2 HP Pavilion zd8000 Switch Cover Replacement: paso 4, imagen 2 de 2
    • Use tweezers to detach the grey and black cables connected to the green WiFi card.
  5. HP Pavilion zd8000 Switch Cover Replacement, Switch Cover: paso 5, imagen 1 de 2 HP Pavilion zd8000 Switch Cover Replacement, Switch Cover: paso 5, imagen 2 de 2
    • Place the laptop face-down and rotate it 180 degrees so the vents are facing you.
    • Remove the five 8mm Philips screws. Three are on the black base and two are near the hinges.
  6. HP Pavilion zd8000 Switch Cover Replacement: paso 6, imagen 1 de 1
    • Flip the laptop over.
    • Fully open the laptop.
  7. HP Pavilion zd8000 Switch Cover Replacement: paso 7, imagen 1 de 3 HP Pavilion zd8000 Switch Cover Replacement: paso 7, imagen 2 de 3 HP Pavilion zd8000 Switch Cover Replacement: paso 7, imagen 3 de 3
    • Rotate it so the display is on your right and the keyboard is on your left.
    • Lift the switch cover firmly but slowly so you do not snap it.
    • Lift the switch cover carefully from one end while sliding the spudger between the switch cover and the laptop to separate them.
    • The switch cover should easily separate from the laptop as you run the spudger through.
Conclusión
Una persona más ha completado esta guía.
Allie Menard
Miembro Desde 04/12/11
820 Reputación
13 Guías creadas
Equipo
Cal Poly, Team 24-56, Amido Spring 2011 Miembro de Cal Poly, Team 24-56, Amido Spring 2011
CPSU-AMIDO-S11S24G56
4 Miembros
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 2,088
