Saltar al contenido principal
HP Pavilion zd8000 Left Speaker Replacement
Qué necesitas
  1. HP Pavilion zd8000 Left Speaker Replacement, Battery: paso 1, imagen 1 de 1
    • Slide the battery release latch towards you.
  2. HP Pavilion zd8000 Left Speaker Replacement: paso 2, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement: paso 2, imagen 2 de 2
    • Pull up on the battery to remove it.
  3. HP Pavilion zd8000 Left Speaker Replacement, RAM: paso 3, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement, RAM: paso 3, imagen 2 de 2
    • Loosen the Phillips screw labeled ‘ram’ and lift the cover.
  4. HP Pavilion zd8000 Left Speaker Replacement: paso 4, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement: paso 4, imagen 2 de 2
    • Locate the green RAM card and find the metal tabs securing the card.
    • Push outwards on the two tabs to release the card.
  5. HP Pavilion zd8000 Left Speaker Replacement: paso 5, imagen 1 de 1
    • Carefully slide the card out at an upward angle away from the slot.
  6. HP Pavilion zd8000 Left Speaker Replacement, WiFi Card Cables: paso 6, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement, WiFi Card Cables: paso 6, imagen 2 de 2
    • Unscrew the four 8mm Philips screws marked with an icon resembling a stacks of discs.
    • Lift the cover from the right to remove it.
  7. HP Pavilion zd8000 Left Speaker Replacement: paso 7, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement: paso 7, imagen 2 de 2
    • Use tweezers to detach the grey and black cables connected to the green WiFi card.
  8. HP Pavilion zd8000 Left Speaker Replacement, CD/Optical Drive: paso 8, imagen 1 de 1
    • Remove the 8mm Philips screw located between the hard drive and the WiFi card.
  9. HP Pavilion zd8000 Left Speaker Replacement: paso 9, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement: paso 9, imagen 2 de 2
    • Turn the laptop 90 degrees clockwise so you are facing the CD drive.
    • Unbend a paperclip and insert the end into the small hole by the eject button to cause the tray to pop out towards you.
  10. HP Pavilion zd8000 Left Speaker Replacement: paso 10, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement: paso 10, imagen 2 de 2
    • Gently pull the tray away from the laptop and the rest of the optical drive will follow.
  11. HP Pavilion zd8000 Left Speaker Replacement, Keyboard: paso 11, imagen 1 de 1
    • Remove the two 8mm Philips screws marked “K” on the bottom of the laptop.
  12. HP Pavilion zd8000 Left Speaker Replacement: paso 12, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement: paso 12, imagen 2 de 2
    • Flip the laptop over and open the screen.
    • Push up on the four latches located at the top of the keyboard with the spudger to release them.
  13. HP Pavilion zd8000 Left Speaker Replacement: paso 13, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement: paso 13, imagen 2 de 2
    • Lift the keyboard carefully because it is attached to the motherboard by a ribbon cable.
    • Lift the top of the keyboard towards you. Then, while keeping the keyboard at an angle, lift it towards the display.
  14. HP Pavilion zd8000 Left Speaker Replacement: paso 14, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement: paso 14, imagen 2 de 2
    • Rotate the keyboard so that the bottom is visible.
    • With the keyboard lifted, locate the blue-striped tab on the underside of the black ribbon cable.
    • Pull the tab towards you to release the keyboard from the laptop.
  15. HP Pavilion zd8000 Left Speaker Replacement, Switch Cover: paso 15, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement, Switch Cover: paso 15, imagen 2 de 2
    • Place the laptop face-down and rotate it 180 degrees so the vents are facing you.
    • Remove the five 8mm Philips screws. Three are on the black base and two are near the hinges.
  16. HP Pavilion zd8000 Left Speaker Replacement: paso 16, imagen 1 de 1
    • Flip the laptop over.
    • Fully open the laptop.
  17. HP Pavilion zd8000 Left Speaker Replacement: paso 17, imagen 1 de 3 HP Pavilion zd8000 Left Speaker Replacement: paso 17, imagen 2 de 3 HP Pavilion zd8000 Left Speaker Replacement: paso 17, imagen 3 de 3
    • Rotate it so the display is on your right and the keyboard is on your left.
    • Lift the switch cover firmly but slowly so you do not snap it.
    • Lift the switch cover carefully from one end while sliding the spudger between the switch cover and the laptop to separate them.
    • The switch cover should easily separate from the laptop as you run the spudger through.
  18. HP Pavilion zd8000 Left Speaker Replacement, Screen: paso 18, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement, Screen: paso 18, imagen 2 de 2
    • Close the lid and rotate the laptop so that the vents are facing you.
    • Unscrew the two 8mm Philips screws below the hinges.
  19. HP Pavilion zd8000 Left Speaker Replacement: paso 19, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement: paso 19, imagen 2 de 2
    • Carefully rotate the laptop 90 degrees counter-clockwise and open the screen.
    • Pull on the black tab with the HP service sticker to unplug the display from the motherboard.
  20. HP Pavilion zd8000 Left Speaker Replacement: paso 20, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement: paso 20, imagen 2 de 2
    • Using tweezers, remove the black cable from the hole leading to the WiFi enclosure.
    • Pull gently to remove the black and grey cables from the case.
    • Check the surface beneath the laptop to ensure the cables do not catch on anything when you flip the laptop over.
  21. HP Pavilion zd8000 Left Speaker Replacement: paso 21, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement: paso 21, imagen 2 de 2
    • Using tweezers, pull the black cable towards the display and through the hole in the casing.
  22. HP Pavilion zd8000 Left Speaker Replacement: paso 22, imagen 1 de 3 HP Pavilion zd8000 Left Speaker Replacement: paso 22, imagen 2 de 3 HP Pavilion zd8000 Left Speaker Replacement: paso 22, imagen 3 de 3
    • Unscrew the two 8mm Philips screws that attach the hinge to the laptop's display.
    • Lift the screen upwards to detach it from the laptop.
  23. HP Pavilion zd8000 Left Speaker Replacement, Top Cover: paso 23, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement, Top Cover: paso 23, imagen 2 de 2
    • With the laptop face-down, remove the eleven 8mm Philips screws.
  24. HP Pavilion zd8000 Left Speaker Replacement: paso 24, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement: paso 24, imagen 2 de 2
    • Rotate the laptop 180 degrees so the vents are facing you.
    • Unscrew the four 3mm Philips screws below the vents.
  25. HP Pavilion zd8000 Left Speaker Replacement: paso 25, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement: paso 25, imagen 2 de 2
    • Rotate the laptop 90 degrees counter-clockwise.
    • Unscrew the two 3mm Philips screws from the optical drive bay.
  26. HP Pavilion zd8000 Left Speaker Replacement: paso 26, imagen 1 de 3 HP Pavilion zd8000 Left Speaker Replacement: paso 26, imagen 2 de 3 HP Pavilion zd8000 Left Speaker Replacement: paso 26, imagen 3 de 3
    • Flip the laptop over so it is face-up with the trackpad closest to you.
    • Locate the ribbon cable directly above the track pad.
    • Find the black latch at the end of the ribbon cable and unlatch it with a spudger to release it.
  27. HP Pavilion zd8000 Left Speaker Replacement: paso 27, imagen 1 de 3 HP Pavilion zd8000 Left Speaker Replacement: paso 27, imagen 2 de 3 HP Pavilion zd8000 Left Speaker Replacement: paso 27, imagen 3 de 3
    • Find the ribbon cable on the LED board located at the top of the laptop.
    • You will notice that the ribbon cable is connected to two levels - you will be dealing with the one on the lower level.
  28. HP Pavilion zd8000 Left Speaker Replacement: paso 28, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement: paso 28, imagen 2 de 2
    • Locate the white connector attached to a red and black cable to the right of the LED board.
    • Using tweezers, pull the white connector away from you.
  29. HP Pavilion zd8000 Left Speaker Replacement: paso 29, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement: paso 29, imagen 2 de 2
    • Unscrew the four 8mm Philips screws from the top cover.
  30. HP Pavilion zd8000 Left Speaker Replacement: paso 30, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement: paso 30, imagen 2 de 2
    • Rotate the computer 90 degrees clockwise and insert the spudger at the seam above the card reader.
    • While lifting the front end of the top cover, slide the spudger across the seam.
    • When you have reached the firewire port, it should click open.
  31. HP Pavilion zd8000 Left Speaker Replacement: paso 31, imagen 1 de 1
    • Lift the top cover from the left side to remove it completely.
  32. HP Pavilion zd8000 Left Speaker Replacement, USB Module: paso 32, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement, USB Module: paso 32, imagen 2 de 2
    • Locate the USB Module
    • Grip the yellow cable cover and pull it to the right to release it.
  33. HP Pavilion zd8000 Left Speaker Replacement: paso 33, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement: paso 33, imagen 2 de 2
    • Unscrew the 6mm Philips screw connecting the USB module to the fan.
  34. HP Pavilion zd8000 Left Speaker Replacement: paso 34, imagen 1 de 1
    • Pull the module to the right and lift it out to release it.
  35. HP Pavilion zd8000 Left Speaker Replacement, Motherboard: paso 35, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement, Motherboard: paso 35, imagen 2 de 2
    • Unscrew and remove the five 4mm Philips screws marked with the white Phillips screw icon.
  36. HP Pavilion zd8000 Left Speaker Replacement: paso 36, imagen 1 de 1
    • Unscrew and remove the two 8mm Philips screws from the heat sink fan.
  37. HP Pavilion zd8000 Left Speaker Replacement: paso 37, imagen 1 de 1
    • Using tweezers, remove the digital drive board cable - the cable set on the right with black, red, green, and white wires.
    • Using tweezers, remove the the rigth speaker cable - the cable set on the left with red and black wires - by pulling the white connector towards you.
  38. HP Pavilion zd8000 Left Speaker Replacement: paso 38, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement: paso 38, imagen 2 de 2
    • Using tweezers, remove the left speaker cable by pulling the white connector towards you.
  39. HP Pavilion zd8000 Left Speaker Replacement: paso 39, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement: paso 39, imagen 2 de 2
    • Remove the LED board cable by pulling the white tab towards you.
  40. HP Pavilion zd8000 Left Speaker Replacement: paso 40, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement: paso 40, imagen 2 de 2
    • Remove the audio cable - the one with the yellow covering located at the bottom-right corner of the motherboard - by pulling the yellow covering towards you.
  41. HP Pavilion zd8000 Left Speaker Replacement: paso 41, imagen 1 de 3 HP Pavilion zd8000 Left Speaker Replacement: paso 41, imagen 2 de 3 HP Pavilion zd8000 Left Speaker Replacement: paso 41, imagen 3 de 3
    • Rotate the laptop 180 degrees and locate the Bluetooth module at the bottom-left corner of the motherboard.
    • Using tweezers, remove the Bluetooth module’s white connector by pulling it away from you.
  42. HP Pavilion zd8000 Left Speaker Replacement: paso 42, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement: paso 42, imagen 2 de 2
    • Using tweezers, pull up on the Bluetooth module to remove it.
  43. HP Pavilion zd8000 Left Speaker Replacement: paso 43, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement: paso 43, imagen 2 de 2
    • Remove the fan cable by pulling the white connector away from you.
  44. HP Pavilion zd8000 Left Speaker Replacement: paso 44, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement: paso 44, imagen 2 de 2
    • Using pliers, unscrew and remove the two bolts from both sides of the blue VGA connector.
  45. HP Pavilion zd8000 Left Speaker Replacement: paso 45, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement: paso 45, imagen 2 de 2
    • Carefully flip the laptop face-down with the battery compartment facing you.
    • Using tweezers, remove the black and red cable from the RAM compartment by pulling on the white connector.
  46. HP Pavilion zd8000 Left Speaker Replacement: paso 46, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement: paso 46, imagen 2 de 2
    • Flip the laptop face-up and turn it so that the drive labelled "hp usb digital drive" faces you.
    • Press the ridged space saver card above the "hp usb digital drive" label to eject and remove it.
  47. HP Pavilion zd8000 Left Speaker Replacement: paso 47, imagen 1 de 3 HP Pavilion zd8000 Left Speaker Replacement: paso 47, imagen 2 de 3 HP Pavilion zd8000 Left Speaker Replacement: paso 47, imagen 3 de 3
    • Locate the PC card below the SD card reader.
    • Push the button to its left once to eject the button itself, then press it once again to remove the PC card.
  48. HP Pavilion zd8000 Left Speaker Replacement: paso 48, imagen 1 de 1
    • Once the PC card pops out, pull it out.
  49. HP Pavilion zd8000 Left Speaker Replacement: paso 49, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement: paso 49, imagen 2 de 2
    • Turn the computer 90 degrees counter-clockwise and clear all cables off of the motherboard.
    • Push in the grey button to the left of the PC card as far as possible.
    • Keeping the button pressed down, lift the motherboard up until the button pops out the top of the case.
  50. HP Pavilion zd8000 Left Speaker Replacement: paso 50, imagen 1 de 1
    • Pull the right casing to the side to release the ports on the motherboard from it.
  51. HP Pavilion zd8000 Left Speaker Replacement: paso 51, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement: paso 51, imagen 2 de 2
    • Lift the motherboard up until it releases from the bottom casing and remove it from the laptop.
  52. HP Pavilion zd8000 Left Speaker Replacement, Left Speaker: paso 52, imagen 1 de 3 HP Pavilion zd8000 Left Speaker Replacement, Left Speaker: paso 52, imagen 2 de 3 HP Pavilion zd8000 Left Speaker Replacement, Left Speaker: paso 52, imagen 3 de 3
    • Pull the USB cable away from the speaker.
  53. HP Pavilion zd8000 Left Speaker Replacement: paso 53, imagen 1 de 1
    • Unscrew the 6mm Philips screw at the back of the left speaker unit.
  54. HP Pavilion zd8000 Left Speaker Replacement: paso 54, imagen 1 de 2 HP Pavilion zd8000 Left Speaker Replacement: paso 54, imagen 2 de 2
    • Lift the speaker unit up, flip it, and remove the USB cable.
  55. HP Pavilion zd8000 Left Speaker Replacement: paso 55, imagen 1 de 1
    • Cut the tape that attaches the USB cable to the left speaker cable.
Conclusión
2 personas más completaron esta guía.
Allie Menard
Miembro Desde 04/12/11
820 Reputación
13 Guías creadas
Equipo
Cal Poly, Team 24-56, Amido Spring 2011 Miembro de Cal Poly, Team 24-56, Amido Spring 2011
CPSU-AMIDO-S11S24G56
4 Miembros
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 46
Todo El Tiempo: 10,802
