Saltar al contenido principal
HP Pavilion dv7-3065dx RAM Replacement
Qué necesitas
  1. HP Pavilion dv7-3065dx RAM Replacement, Battery: paso 1, imagen 1 de 2 HP Pavilion dv7-3065dx RAM Replacement, Battery: paso 1, imagen 2 de 2
    • Turn off the device before removing the battery.
    • Place the laptop upside down on a flat surface so that the bottom is facing up.
    • The battery is the long rectangle above the latch.
  2. HP Pavilion dv7-3065dx RAM Replacement: paso 2, imagen 1 de 1
    • Slide the battery latch to the left to release the battery.
  3. HP Pavilion dv7-3065dx RAM Replacement: paso 3, imagen 1 de 2 HP Pavilion dv7-3065dx RAM Replacement: paso 3, imagen 2 de 2
    • Carefully pull out the battery while holding the latch to the open position with your finger.
  4. HP Pavilion dv7-3065dx RAM Replacement, RAM: paso 4, imagen 1 de 1
    • Remove the four circled screws using a #1 philips head screwdriver
    • Note: Be sure to leave the screws in the pannel
    • Pry off cover and place to the side.
  5. HP Pavilion dv7-3065dx RAM Replacement: paso 5, imagen 1 de 1
    • The RAM modules will be found on the right side of the access panel
    • CAUTION - The RAM modules are sensitive to electrostatic discharge. It is recommended to wear an anti static bracelet while handling the RAM.
  6. HP Pavilion dv7-3065dx RAM Replacement: paso 6, imagen 1 de 2 HP Pavilion dv7-3065dx RAM Replacement: paso 6, imagen 2 de 2
    • To remove RAM modules, pry metal tabs out of the modules, and pull ram out (Starting from the top RAM module).
    • Note: The RAM Modules pop out away from the motherboard. In order to replace them, slot the gold plated end into the terminal and push down towards the motherboard.
Conclusión
3 personas más completaron esta guía.
Jonathan Winkler
Miembro Desde 02/06/17
161 Reputación
1 Guía escrita
Equipo
Ohio State, Team 1-5, Wilder Spring 2017 Miembro de Ohio State, Team 1-5, Wilder Spring 2017
OSU-WILDER-S17S1G5
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 17
Todo El Tiempo: 1,263
