Introducción
Replace the wireless card in your HP Pavilion dv6000.
Lay the laptop on a flat surface, battery side up.
  • Lay the laptop on a flat surface, battery side up.
  • Remove the two screws securing the RAM shield to the lower case.
  • The screws will remain captive within the shield.
  • Lift and remove the RAM shield up from the lower case.
Agregar Comentario
Use a pair of tweezers to disconnect both antennas from their sockets on the wireless card. Be careful to pull on the contacts and not the wires. The crimps used to hold them to the wires are delicate.
  • Use a pair of tweezers to disconnect both antennas from their sockets on the wireless card.
  • Be careful to pull on the contacts and not the wires. The crimps used to hold them to the wires are delicate.
Agregar Comentario
Remove the two 3.7 mm Phillips screws securing the wireless card to the motherboard.
  • Remove the two 3.7 mm Phillips screws securing the wireless card to the motherboard.
  • Upon removing the Phillips screws that secures the wireless card to the motherboard, the wireless card board should pop up from its top side.
  • Grasp the wireless card and pull it straight out of its socket on the motherboard.
Agregar Comentario
Wireless card remains.
  • Wireless card remains.
Agregar Comentario
Conclusión
4 personas más completaron esta guía.
Ben Hirsch
Miembro Desde 05/10/10
3,577 Reputación
10 Guías creadas
Equipo
Cal Poly, Team 21-33, Regan Fall 2010 Miembro de Cal Poly, Team 21-33, Regan Fall 2010
CPSU-REGAN-F10S21G33
4 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 9
Últimos 30 Días: 77
Todo El Tiempo: 24,725
