Introducción
If you need more memory because your computer is running slowly, or you are having memory problems, the RAM is very easy to replace in the HP Pavilion dv6000.
Remove the two screws from the memory shield and lift up.  The screws will remain into the shield Remove the two screws from the memory shield and lift up.  The screws will remain into the shield Remove the two screws from the memory shield and lift up.  The screws will remain into the shield
  • Remove the two screws from the memory shield and lift up. The screws will remain into the shield
Agregar Comentario
Using a plastic spudger depress the pins holding the RAM in. If you  have an anti-static work surface or wristband, you may suppress the pins with your thumbs. Static charge built up on surfaces contacting the RAM or other computer components can damage and destroy the components.  Always discharge yourself before handling these components! Pull the RAM straight out.
  • Using a plastic spudger depress the pins holding the RAM in. If you have an anti-static work surface or wristband, you may suppress the pins with your thumbs.
  • Static charge built up on surfaces contacting the RAM or other computer components can damage and destroy the components. Always discharge yourself before handling these components!
  • Pull the RAM straight out.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Under the first RAM stick is another. Remove it in the same way by pushing the silver tabs away and down from the RAM stick and remove the RAM once it pops up.
  • Under the first RAM stick is another. Remove it in the same way by pushing the silver tabs away and down from the RAM stick and remove the RAM once it pops up.
Agregar Comentario
You have removed your RAM!
  • You have removed your RAM!
  • If you want to expand your RAM you will have to use PC2-5300 SODIMM laptop memory modules, they are clocked at 667MHz
  • To reinstall your RAM, follow this guide in the reverse order
Agregar Comentario
Conclusión
17 personas más completaron esta guía.
Ben Hirsch
Miembro Desde 05/10/10
3,568 Reputación
10 Guías creadas
Equipo
Cal Poly, Team 21-33, Regan Fall 2010 Miembro de Cal Poly, Team 21-33, Regan Fall 2010
CPSU-REGAN-F10S21G33
4 Miembros
10 Guías creadas
if you have bios version f.25 or newer you can have up to 4gb of ram
Bryce Stidman - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 4
Últimos 7 Días: 28
Últimos 30 Días: 165
Todo El Tiempo: 30,582
