Introducción
Replace the optical drive assembly in your HP Pavilion dv6000.
Partes
No se requieren partes.
Before proceeding, it is recommended to remove the battery to prevent any electrical damage to components.
  • Before proceeding, it is recommended to remove the battery to prevent any electrical damage to components.
  • Remove the single 5.6 mm Phillips screw securing the optical drive to the lower case.
Agregar Comentario
Insert the tip of an unrolled paper clip into the small hole located on the side of the optical drive.
  • Insert the tip of an unrolled paper clip into the small hole located on the side of the optical drive.
  • The tray will partially pop out of the laptop.
  • Firmly pull the drive straight away from the laptop.
  • While pulling the drive out, be careful not to bend the sliding rails on both sides of the optical drive.
  • At this point you can remove the entire optical drive, or you can continue to disassemble the optical drive assembly.
Agregar Comentario
Remove the three 3.2 mm screws securing the top plate of the optical drive. Lift and remove the top plate up off the optical drive.
  • Remove the three 3.2 mm screws securing the top plate of the optical drive.
  • Lift and remove the top plate up off the optical drive.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Lift and remove the optical drive assembly.
  • Lift and remove the optical drive assembly.
  • It may be helpful to gently "rock" the drive assembly side to side to dislodge it from its recess.
  • For the rest of the guide, be careful to not touch any of the circuitry on the board as well as the laser lens!
Agregar Comentario
Flip the drive over.
  • Flip the drive over.
  • Pull the small ribbon cable straight away from its socket on the optical drive assembly board.
Agregar Comentario
Use your fingernail to flip up the cable retaining flap on the ZIF socket for the larger ribbon cable.
  • Use your fingernail to flip up the cable retaining flap on the ZIF socket for the larger ribbon cable.
  • Pull the larger ribbon cable straight out of its socket on the optical drive assembly board.
Agregar Comentario
Lift and remove the optical drive assembly from the optical drive framework.
  • Lift and remove the optical drive assembly from the optical drive framework.
  • Optical drive assembly remains.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Ben Hirsch
Miembro Desde 05/10/10
3,568 Reputación
10 Guías creadas
Equipo
Cal Poly, Team 21-33, Regan Fall 2010 Miembro de Cal Poly, Team 21-33, Regan Fall 2010
CPSU-REGAN-F10S21G33
4 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 5
Últimos 30 Días: 13
Todo El Tiempo: 6,328
