Introducción
If your keyboard is not responding or you want to add in a new one, this guide is for you.
Remove the battery from the back of the computer. Remove the two 7.2mm screws underneath holding the keyboard in. Remove the battery from the back of the computer. Remove the two 7.2mm screws underneath holding the keyboard in.
  • Remove the battery from the back of the computer. Remove the two 7.2mm screws underneath holding the keyboard in.
Agregar Comentario
Flip the laptop back over (keyboard side up). Pop the bezel off of the case by reaching underneath it. Carefully remove the three ribbons underneath the bezel which attach it to the computer.
  • Flip the laptop back over (keyboard side up).
  • Pop the bezel off of the case by reaching underneath it.
  • Carefully remove the three ribbons underneath the bezel which attach it to the computer.
Agregar Comentario
Gently lift the keyboard out of the casing by holding the top edge (as shown).  Be careful to keep the lower edge of the keyboard in place as you lift because there is a ribbon attached to the back (marked in red). The keyboard is held in by six small tabs (2 on the top and 4 on the bottom).  Lifting the bevel frees the top two.  Free the bottom four tabs by sliding the keyboard forward towards the screen.
  • Gently lift the keyboard out of the casing by holding the top edge (as shown). Be careful to keep the lower edge of the keyboard in place as you lift because there is a ribbon attached to the back (marked in red).
  • The keyboard is held in by six small tabs (2 on the top and 4 on the bottom). Lifting the bevel frees the top two. Free the bottom four tabs by sliding the keyboard forward towards the screen.
Agregar Comentario
Remove the ribbon from the computer by pulling straight back (away from the track pad and towards the monitor). Remove the ribbon from the computer by pulling straight back (away from the track pad and towards the monitor).
  • Remove the ribbon from the computer by pulling straight back (away from the track pad and towards the monitor).
Agregar Comentario
DONE!
  • DONE!
Agregar Comentario
Conclusión
10 personas más completaron esta guía.
Ben Hirsch
Miembro Desde 05/10/10
3,568 Reputación
10 Guías creadas
Equipo
Cal Poly, Team 21-33, Regan Fall 2010 Miembro de Cal Poly, Team 21-33, Regan Fall 2010
CPSU-REGAN-F10S21G33
4 Miembros
10 Guías creadas
Actually, there are three screws in the step 1.
The third one is hidden under the cover for the memory box!!!
Be careful, otherwise the dammage is granted.
harley029 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 10
Últimos 30 Días: 84
Todo El Tiempo: 21,786
