Saltar al contenido principal
HP Pavilion dv6000 Camera Replacement
Qué necesitas
  1. HP Pavilion dv6000 Camera Replacement, Camera: paso 1, imagen 1 de 2 HP Pavilion dv6000 Camera Replacement, Camera: paso 1, imagen 2 de 2
    • Remove rubber screw covers from the LCD screen. They cover the screws. The stops on the top of the screen pop off, but the lower covers require a screwdriver to remove.
    • If you need to use the screwdriver to remove the rubber screw covers, gently push the screwdriver down the edge of the stopper and then use the screwdriver as a lever to pry the cover from the hole.
    • Remove the six 7.15mm screws underneath the stoppers. There are four on top and two on bottom.
  2. HP Pavilion dv6000 Camera Replacement: paso 2, imagen 1 de 3 HP Pavilion dv6000 Camera Replacement: paso 2, imagen 2 de 3 HP Pavilion dv6000 Camera Replacement: paso 2, imagen 3 de 3
    • Press the tabs in on the sides of the screen and pop the plastic covering off.
    • The edges of the LCD screen are very sharp. Take care to not cut your fingers!
  3. HP Pavilion dv6000 Camera Replacement: paso 3, imagen 1 de 1
    • Lift the screen out of the casing at the top near the camera.
    • Take care to not snap the plastic casing! It is brittle and still attached to the bottom of the screen.
  4. HP Pavilion dv6000 Camera Replacement: paso 4, imagen 1 de 1
    • Gently remove the main cable from the camera.
  5. HP Pavilion dv6000 Camera Replacement: paso 5, imagen 1 de 2 HP Pavilion dv6000 Camera Replacement: paso 5, imagen 2 de 2
    • There are three clasps holding the camera down. Gingerly lift the camera board up, being careful not to snap the board, clasps, or vertical plastic pins (inside the gold-colored rings).
    • The metal tabs to the left and right of the camera (for the LCD) are sharp, watch your fingers!
  6. HP Pavilion dv6000 Camera Replacement: paso 6, imagen 1 de 1
    • Remove the camera unit from the laptop and you are done!
Conclusión
3 personas más completaron esta guía.
Ben Hirsch
Miembro Desde 10/05/10
3,826 Reputación
10 Guías creadas
Equipo
Cal Poly, Team 21-33, Regan Fall 2010 Miembro de Cal Poly, Team 21-33, Regan Fall 2010
CPSU-REGAN-F10S21G33
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 9,996
