Introducción
The HP Pavilion dv5000 Wifi Card allows for wireless network connectivity. It is located on the mother board, beneath the RAM memory/Wifi compartment cover.
Partes
No se requieren partes.
Turn off down the computer, and unplug the computer from all external power sources.
  • Turn off down the computer, and unplug the computer from all external power sources.
  • Shut the screen, and lay the computer face-down on a flat, sturdy surface. Orient the computer to match the image.
  • Locate the battery release switch, as indicated in the image. Sliding this switch from right to left will release the battery.
  • Remove the battery.
Agregar Comentario
Remove the two 5mm screws securing the right side of the RAM cover to the computer frame. Lift the right side of the RAM cover to remove. Lift the right side of the RAM cover to remove.
  • Remove the two 5mm screws securing the right side of the RAM cover to the computer frame.
  • Lift the right side of the RAM cover to remove.
Agregar Comentario
Guía de regalos para el día del padre
Honremos a más que nuestros padres—celebremos a todos los mentores que nos enseñaron a reparar.
Honremos a aquellos que nos enseñaron a reparar.
The wifi card is connected to the computer with the two antenna lead wires.
  • The wifi card is connected to the computer with the two antenna lead wires.
  • Note where the white AUX wire and the black MAIN wire connect to the wifi card before disconnecting.
Agregar Comentario
Disconnect the antenna leads from the wifi card by lifting the gold ends of the wires off the prongs on the wifi card. The white wire connects to the AUX terminal.
  • Disconnect the antenna leads from the wifi card by lifting the gold ends of the wires off the prongs on the wifi card.
    • The white wire connects to the AUX terminal.
    • The black wire connects to the MAIN terminal.
Agregar Comentario
Remove the two 6.0mm screws securing the wifi card to the computer.
  • Remove the two 6.0mm screws securing the wifi card to the computer.
Agregar Comentario
Remove the wifi card.
  • Remove the wifi card.
Agregar Comentario
Conclusión
Sam Kaplan
Miembro Desde 11/10/10
223 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 21-34, Regan Fall 2010 Miembro de Cal Poly, Team 21-34, Regan Fall 2010
CPSU-REGAN-F10S21G34
4 Miembros
11 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 5
Últimos 30 Días: 30
Todo El Tiempo: 5,480
