Introducción
The motherboard is the main part of the computer and houses the CPU and GPU. Although it is rare to encounter problems with the motherboard, it needs to be removed to access the fan and heat sink underneath.
Partes
No se requieren partes.
Turn off down the computer, and unplug the computer from all external power sources.
  • Turn off down the computer, and unplug the computer from all external power sources.
  • Shut the screen, and lay the computer face-down on a flat, sturdy surface. Orient the computer to match the image.
  • Locate the battery release switch, as indicated in the image. Sliding this switch from right to left will release the battery.
  • Remove the battery.
Agregar Comentario
Locate the hard drive cover. Note that in this image, the RAM cover is still in place.
  • Locate the hard drive cover. Note that in this image, the RAM cover is still in place.
Agregar Comentario
Remove the two screws securing the hard drive cover.
  • Remove the two screws securing the hard drive cover.
Agregar Comentario
Remove the hard drive cover. The hard drive is now accessible.
  • Remove the hard drive cover.
  • The hard drive is now accessible.
Agregar Comentario
Remove the two 5.0mm screws securing the hard drive bracket.
  • Remove the two 5.0mm screws securing the hard drive bracket.
Agregar Comentario
Slide the hard drive to the right until the edge of the hard drive is flush with the computer frame. Lift the hard drive out of the hard drive bay, left side first. Lift the hard drive out of the hard drive bay, left side first.
  • Slide the hard drive to the right until the edge of the hard drive is flush with the computer frame.
  • Lift the hard drive out of the hard drive bay, left side first.
Agregar Comentario
Remove the hard drive.
  • Remove the hard drive.
  • If you are replacing the hard drive, remove the four additional screws (two on each side) securing the metal shield to the hard drive. Then, remove the shield from the drive.
Agregar Comentario
Remove the two 5mm screws securing the right side of the RAM cover to the computer frame. Lift the right side of the RAM cover to remove. Lift the right side of the RAM cover to remove.
  • Remove the two 5mm screws securing the right side of the RAM cover to the computer frame.
  • Lift the right side of the RAM cover to remove.
Agregar Comentario
Release the RAM by pressing the metal heads of the RAM clips to the sides. Use tweezers and the spudger to spread the clips until they are completely off the RAM.
  • Release the RAM by pressing the metal heads of the RAM clips to the sides. Use tweezers and the spudger to spread the clips until they are completely off the RAM.
  • There are two RAM cards in this device.
Agregar Comentario
Remove the RAM. Remove the RAM. Remove the RAM.
  • Remove the RAM.
Agregar Comentario
As in step 3, press the clips on both sides to release the second RAM clip.
  • As in step 3, press the clips on both sides to release the second RAM clip.
Agregar Comentario
  • Remove the RAM.
Agregar Comentario
Remove the 11.0mm screw securing the optical drive to the computer.
  • Remove the 11.0mm screw securing the optical drive to the computer.
Agregar Comentario
Guía de regalos para el día del padre
Honremos a más que nuestros padres—celebremos a todos los mentores que nos enseñaron a reparar.
Honremos a aquellos que nos enseñaron a reparar.
Locate the optical drive. The optical drive is located on the left side of the RAM bay. Press the exposed edge of the optical drive gently with the spudger until the drive releases from the computer frame. Pull the optical drive completely out of the computer frame.
  • Locate the optical drive. The optical drive is located on the left side of the RAM bay.
  • Press the exposed edge of the optical drive gently with the spudger until the drive releases from the computer frame.
  • Pull the optical drive completely out of the computer frame.
Agregar Comentario
The wifi card is connected to the computer with the two antenna lead wires.
  • The wifi card is connected to the computer with the two antenna lead wires.
  • Note where the white AUX wire and the black MAIN wire connect to the wifi card before disconnecting.
Agregar Comentario
Disconnect the antenna leads from the wifi card by lifting the gold ends of the wires off the prongs on the wifi card. The white wire connects to the AUX terminal.
  • Disconnect the antenna leads from the wifi card by lifting the gold ends of the wires off the prongs on the wifi card.
    • The white wire connects to the AUX terminal.
    • The black wire connects to the MAIN terminal.
Agregar Comentario
Remove the two 6.0mm screws securing the wifi card to the computer.
  • Remove the two 6.0mm screws securing the wifi card to the computer.
Agregar Comentario
Remove the wifi card.
  • Remove the wifi card.
Agregar Comentario
Remove the two 11.0mm screws at the corners on either side of the battery compartment.
  • Remove the two 11.0mm screws at the corners on either side of the battery compartment.
  • Remove the three 6.0mm screws.
  • Remove the two 5.0mm screws.
  • Remove the 6.0mm screw in the middle of the battery compartment.
Agregar Comentario
Turn the computer over and open the screen. This provides access to the screen hinges.
  • Turn the computer over and open the screen. This provides access to the screen hinges.
  • The keyboard switch cover is attached to the computer with a series of snaps. With a flathead screwdriver, pry up the switch cover until it pops free.
Agregar Comentario
Be careful not to bend the keyboard switch cover too far when removing it.
  • Be careful not to bend the keyboard switch cover too far when removing it.
Agregar Comentario
Next, remove the keyboard. Push on the keyboard frame above the function keys and slide the keyboard toward the screen.
  • Next, remove the keyboard. Push on the keyboard frame above the function keys and slide the keyboard toward the screen.
Agregar Comentario
Carefully lift the trackpad-side edge of the keyboard to reveal the LED and keyboard cable connectors. Detach the cable connectors from the computer by gripping each cable connector close to the computer contact point and pulling up gently.
  • Carefully lift the trackpad-side edge of the keyboard to reveal the LED and keyboard cable connectors.
  • Detach the cable connectors from the computer by gripping each cable connector close to the computer contact point and pulling up gently.
Agregar Comentario
This step is for replacing the keyboard only. If you are not replacing the keyboard, skip this step.
  • This step is for replacing the keyboard only. If you are not replacing the keyboard, skip this step.
    • Lay the keyboard face down.
    • Remove the four 3.00mm screws that attach the keyboard to the keyboard frame.
Agregar Comentario
    • Lift the keyboard off the keyboard frame.
Agregar Comentario
Use the plastic prying tool to disconnect the screen cable from the system board. Use the plastic prying tool to disconnect the screen cable from the system board.
  • Use the plastic prying tool to disconnect the screen cable from the system board.
Agregar Comentario
Remove the four 7.0mm screws securing the screen to the computer. Remove the four 7.0mm screws securing the screen to the computer.
  • Remove the four 7.0mm screws securing the screen to the computer.
Agregar Comentario
Separate the screen from the computer frame by lifting the screen straight up. Disconnect the PCI wires by pulling them free of the computer.
  • Separate the screen from the computer frame by lifting the screen straight up.
  • Disconnect the PCI wires by pulling them free of the computer.
Agregar Comentario
Flip the computer over to access the screws on the underside of the frame.
  • Flip the computer over to access the screws on the underside of the frame.
  • Remove the two 3.0mm screws.
  • Remove the 5.0mm screw.
Agregar Comentario
Remove the eight 10mm screws.
  • Remove the eight 10mm screws.
Agregar Comentario
Flip the computer over so the touchpad is accessible. Disconnect the touchpad cable by pulling on it gently.
  • Flip the computer over so the touchpad is accessible.
  • Disconnect the touchpad cable by pulling on it gently.
Agregar Comentario
Remove the three 5.0mm screws in the silver panel. Remove the seven 10.0mm screws.
  • Remove the three 5.0mm screws in the silver panel.
  • Remove the seven 10.0mm screws.
Agregar Comentario
Lift the top cover off of the rest of the computer frame.
  • Lift the top cover off of the rest of the computer frame.
Agregar Comentario
Press gently on the textured front of the Express Card, then release it. It will pop out of the slot. Remove the Express Card from the Express Card slot. Remove the Express Card from the Express Card slot.
  • Press gently on the textured front of the Express Card, then release it. It will pop out of the slot.
  • Remove the Express Card from the Express Card slot.
Agregar Comentario
Remove the 6.0mm screw that secures the display hinge support to the computer frame. Remove the display hinge support. Disconnect the power connector cable.
  • Remove the 6.0mm screw that secures the display hinge support to the computer frame.
  • Remove the display hinge support.
  • Disconnect the power connector cable.
Agregar Comentario
Disconnect the USB audio cable and the modem cable.
  • Disconnect the USB audio cable and the modem cable.
Agregar Comentario
Press gently on the front of the wireless card, then release it. It will pop out of the slot. Remove the wireless card from the wireless card slot.
  • Press gently on the front of the wireless card, then release it. It will pop out of the slot.
  • Remove the wireless card from the wireless card slot.
Agregar Comentario
Remove the 10.0mm screw. Remove the two 6.0mm screws securing the Express Card bracket. Remove the Express Card bracket
  • Remove the 10.0mm screw.
  • Remove the two 6.0mm screws securing the Express Card bracket.
  • Remove the Express Card bracket
Agregar Comentario
Lift the system board off the computer frame. Lift the system board off the computer frame.
  • Lift the system board off the computer frame.
Agregar Comentario
Conclusión
5 personas más completaron esta guía.
Equipo
Cal Poly, Team 21-34, Regan Fall 2010 Miembro de Cal Poly, Team 21-34, Regan Fall 2010
CPSU-REGAN-F10S21G34
4 Miembros
11 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 6
Últimos 30 Días: 24
Todo El Tiempo: 15,906
