Introducción
The HP Pavilion dv1000 series had a battery recall several years ago due to overheating batteries. This guide will show you how to replace your old battery with a new one.
The battery is the main source of power for your laptop. Without a battery, the laptop cannot be powered on unless it is plugged into a wall socket.
Replacing the battery is a very easy task with very little risk of damaging critical components inside your laptop.
Shut down the computer.
  • Shut down the computer.
  • Disconnect all external devices and cables from the computer.
Agregar Comentario
Flip the laptop over.
  • Flip the laptop over.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Locate the gray sliding tab next to the black bar where the battery is located. Slide the gray sliding tab to the left until you hear a distinct click.
  • Locate the gray sliding tab next to the black bar where the battery is located.
  • Slide the gray sliding tab to the left until you hear a distinct click.
  • The inside edge of the battery should pop up.
Agregar Comentario
Grasp the inside edge of the battery. Lift the inside edge of the battery up to detach the battery from the laptop. Lift the inside edge of the battery up to detach the battery from the laptop.
  • Grasp the inside edge of the battery.
  • Lift the inside edge of the battery up to detach the battery from the laptop.
Agregar Comentario
Conclusión
John Park
Miembro Desde 06/04/11
204 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 10-37, Forte Spring 2011 Miembro de Cal Poly, Team 10-37, Forte Spring 2011
CPSU-FORTE-S11S10G37
5 Miembros
9 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 7
Últimos 30 Días: 17
Todo El Tiempo: 3,464
