Introducción
This guide will show you how to remove the fans.
Partes
No se requieren partes.
Begin by turning the laptop over so that you can see the bottom of the computer.
  • Begin by turning the laptop over so that you can see the bottom of the computer.
Agregar Comentario
Slide the battery release switch to the right while simultaneously lifting up the battery.
  • Slide the battery release switch to the right while simultaneously lifting up the battery.
Agregar Comentario
Loosen the 8 Phillips screws around the plate and remove the plate.
  • Loosen the 8 Phillips screws around the plate and remove the plate.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the 9 Phillips screws from the plate covering the fans.
  • Remove the 9 Phillips screws from the plate covering the fans.
  • The 3 screws around the lower fan also hold the fan onto the metal plate.
Agregar Comentario
Lift the plate and lower fan off the heat sink being careful not to damage the lower fan cable, which is attached to the motherboard.
  • Lift the plate and lower fan off the heat sink being careful not to damage the lower fan cable, which is attached to the motherboard.
  • Disconnect the lower fan connector from the motherboard.
  • Remove the metal plate and lower fan.
  • The lower fan will easily separate from the metal plate.
Agregar Comentario
Disconnect the upper fan connector from the motherboard.
  • Disconnect the upper fan connector from the motherboard.
  • Remove the 4 spring loaded screws holding the heat sink assembly to the motherboard.
  • When reassembling, thread all screws in 1 - 1 1/2 turns then alternately tighten each screw 1 turn - starting top left, then bottom right, then bottom left, then top right, then top left again etc. until the heat sink assembly is firmly seated and all screws are tightened the same amount.
Agregar Comentario
Slide the heat sink assembly including the upper fan out by pulling it down and left simultaneously.
  • Slide the heat sink assembly including the upper fan out by pulling it down and left simultaneously.
  • When reinstalling heat sink, ensure it is thoroughly cleaned and the thermal paste (or pads ) are replaced to ensure proper thermal contact with the devices on the logic board to prevent thermal issues.
Agregar Comentario
Conclusión
3 personas más completaron esta guía.
Shantel
Miembro Desde 20/04/10
470 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 30-37, Garner Spring 2010 Miembro de Cal Poly, Team 30-37, Garner Spring 2010
CPSU-GARNER-S10S30G37
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 6
Todo El Tiempo: 6,136
