Saltar al contenido principal
HP Pavilion G7-2289wm Fan and Heat Sink Replacement
Qué necesitas
  1. HP Pavilion G7-2289wm Fan and Heat Sink Replacement, Battery: paso 1, imagen 1 de 1
    • Located on the bottom side of your laptop, slide the battery release latch to the left, towards the center of the laptop.
    • Lift the battery up, and pull towards the center of the laptop to remove it.
  2. HP Pavilion G7-2289wm Fan and Heat Sink Replacement, Optical Drive: paso 2, imagen 1 de 1
    • Loosen the screw that secures the service cover using a Phillips #0 screwdriver.
    • Lift the edge of the service cover up and forward until it’s at an angle to remove it.
  3. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: paso 3, imagen 1 de 2 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: paso 3, imagen 2 de 2
    • Remove the screw that secures the optical drive to the laptop using a Phillips #0 screwdriver.
    • Slide the optical drive out of the laptop.
  4. HP Pavilion G7-2289wm Fan and Heat Sink Replacement, Hard Drive: paso 4, imagen 1 de 1
    • Pull the edge of the service cover toward you to remove it.
  5. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: paso 5, imagen 1 de 1
    • Disconnect the hard drive connector cable from the motherboard.
  6. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: paso 6, imagen 1 de 1
    • Lift the front edge of the hard drive, then pull the hard drive out gently.
  7. HP Pavilion G7-2289wm Fan and Heat Sink Replacement, Keyboard: paso 7, imagen 1 de 1
    • Remove all the screw that secures the keyboard to the computer using a Phillips #0 screwdriver.
  8. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: paso 8, imagen 1 de 3 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: paso 8, imagen 2 de 3 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: paso 8, imagen 3 de 3
    • Flip your laptop around to the front, using an opening tool, pry around the perimeter of the keyboard.
    • Lift the keyboard from the top backward towards the touch pad.
    • Unlatch the keyboard connector from the motherboard and remove the keyboard.
  9. HP Pavilion G7-2289wm Fan and Heat Sink Replacement, Fan and Heat Sink: paso 9, imagen 1 de 1
    • Remove the three screws that hold the keyboard palm rest in place using a Phillips #0 screwdriver.
    • Lift the palm rest up and out.
  10. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: paso 10, imagen 1 de 3 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: paso 10, imagen 2 de 3 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: paso 10, imagen 3 de 3
    • Remove the wires attached under the keyboard.
  11. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: paso 11, imagen 1 de 1
    • Pry open the bottom of the laptop by using the opening tool to open it up. Do this around the entire outer edge of the laptop.
  12. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: paso 12, imagen 1 de 3 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: paso 12, imagen 2 de 3 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: paso 12, imagen 3 de 3
    • Remove the screw that holds the motherboard in place.
    • Remove the wires attached to the motherboard.
    • Unplug the laptop fan.
  13. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: paso 13, imagen 1 de 1
    • Remove the four screws that hold the fan and heat sink in place.
    • Remove the entire heat sink from the laptop.
Conclusión
Clayton LaBrecque
Miembro Desde 03/19/18
171 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 17
Todo El Tiempo: 422
