Introducción
The hard drive can cause the device to run slow. In this guide, you will learn how to replace your HP Pavilion 17-g119dx laptop's hard drive. To perform the replacement, you will need a Phillips head screwdriver and a plastic opening tool to pop open the keyboard.
Qué necesitas
Remove the twenty 6.5mm screws using the Phillips #00 screwdriver.
Two of these 6.5mm screws are covered by a silver sticker. Remove the sticker by gently scraping your finger nail under the sticker and then remove the screws.
Herramienta utilizada en este paso:iFixit Opening Tool$1.99
Flip the computer back over with the screen facing up and open the laptop.
Use the Plastic Opening Tool to separate the face plate from the backing.
18 personas más completaron esta guía.
2 comentarios
Thnx indeed very helpful.
