Introducción
By following this guide, you will be able to replace the CD Drive. The drive is probably the easiest part to replace on the laptop.
Partes
No se requieren partes.
Make sure the laptop is off and unplugged before starting.
  • Make sure the laptop is off and unplugged before starting.
  • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
Agregar Comentario
Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel. Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
  • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
Agregar Comentario
Using the plastic opening tool, remove the back cover of the laptop. It is recommended that you start with a corner and run the tool throughout the edges of the cover.
  • Using the plastic opening tool, remove the back cover of the laptop.
  • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
  • Be sure not to bend the cover by applying too much force.
Agregar Comentario
Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place. Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
  • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
Agregar Comentario
Carefully disconnect the cable connecting the top of the battery and remove the battery. Carefully disconnect the cable connecting the top of the battery and remove the battery. Carefully disconnect the cable connecting the top of the battery and remove the battery.
  • Carefully disconnect the cable connecting the top of the battery and remove the battery.
Agregar Comentario
The CD Drive is located at the bottom right area of the motherboard.
  • The CD Drive is located at the bottom right area of the motherboard.
Agregar Comentario
Disconnect the CD drive from the motherboard connector on the left. Disconnect the CD drive from the motherboard connector on the left.
  • Disconnect the CD drive from the motherboard connector on the left.
Agregar Comentario
Conclusión
Mohammad Gardezi
Miembro Desde 17/10/17
649 Reputación
6 Guías creadas
Equipo
USF Tampa, Team S13-G3, Cagle Fall 2017 Miembro de USF Tampa, Team S13-G3, Cagle Fall 2017
USFT-CAGLE-F17S13G3
2 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 8
Todo El Tiempo: 77
