Introducción
The scanner tray is the part of the printer that houses the entire scanner. It is connected to the printer by two hinges, 3 white strip wires, and 1 orange brown red and black wire. After the tray is removed the feed rollers can be cleaned, and printer carriage can be replaced.
Partes
No se requieren partes.
Remove the back panel by inserting your fingers into the indentations next to the tabs. Press the tabs inward towards each other while pulling the back panel toward you.
  • Remove the back panel by inserting your fingers into the indentations next to the tabs. Press the tabs inward towards each other while pulling the back panel toward you.
Agregar Comentario
Using the T10 Torx Security Bit Screwdriver, unscrew the screws on the upper left and right corners of the inner panel to remove the inner back panel. Using the T10 Torx Security Bit Screwdriver, unscrew the screws on the upper left and right corners of the inner panel to remove the inner back panel.
  • Using the T10 Torx Security Bit Screwdriver, unscrew the screws on the upper left and right corners of the inner panel to remove the inner back panel.
Agregar Comentario
Press down on the two plastic hinges to remove the upper portion of printer. Press down on the two plastic hinges to remove the upper portion of printer.
  • Press down on the two plastic hinges to remove the upper portion of printer.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
To unplug the speaker wire, grasp the plastic plug on the end of the speaker wire then gently pull the plug away from the printer until removed.
  • To unplug the speaker wire, grasp the plastic plug on the end of the speaker wire then gently pull the plug away from the printer until removed.
Agregar Comentario
Rotate the printer so the paper tray is facing towards you. Gently lift the scanner tray up and away from the printer.
  • Rotate the printer so the paper tray is facing towards you.
  • Gently lift the scanner tray up and away from the printer.
  • Press the gray plastic tabs inward toward to release the tabs from the printer.
Agregar Comentario
Returning to the back of the printer, remove the scanner from the back hinges.
  • Returning to the back of the printer, remove the scanner from the back hinges.
    • With pressure applied, the scanner will detach easily.
It would be easer to do steps 7 & 8 before step 6.
Richard Scott - Contestar
Gently grasp and unplug the two white ribbon cables from the printer body.
  • Gently grasp and unplug the two white ribbon cables from the printer body.
    • Be sure to grasp the cable at the connector and not to pull on the wires themselves.
Agregar Comentario
Unplug the white plastic multi-wire connector with the orange, black, red, and brown wires from it's port.
  • Unplug the white plastic multi-wire connector with the orange, black, red, and brown wires from it's port.
    • Be sure to grasp the white connector and not to pull on the wires themselves.
Agregar Comentario
Detach the scanner tray from the printer by lifting the scanner tray off the printer body.
  • Detach the scanner tray from the printer by lifting the scanner tray off the printer body.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Documentos Adjuntos
Cody Long
Miembro Desde 12/04/11
144 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 12-31, Maness Spring 2011 Miembro de Cal Poly, Team 12-31, Maness Spring 2011
CPSU-MANESS-S11S12G31
5 Miembros
9 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 5
Últimos 30 Días: 15
Todo El Tiempo: 5,147
