Saltar al contenido principal
HP Mini 311 WWAN Card Replacement
Qué necesitas
  1. HP Mini 311 WWAN Card Replacement, Battery: paso 1, imagen 1 de 3 HP Mini 311 WWAN Card Replacement, Battery: paso 1, imagen 2 de 3 HP Mini 311 WWAN Card Replacement, Battery: paso 1, imagen 3 de 3
    • Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
  2. HP Mini 311 WWAN Card Replacement: paso 2, imagen 1 de 2 HP Mini 311 WWAN Card Replacement: paso 2, imagen 2 de 2
    • Slide the battery away from the device to remove.
  3. HP Mini 311 WWAN Card Replacement, Memory Shield: paso 3, imagen 1 de 1
    • With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
    • The screws will remain in the shied.
  4. HP Mini 311 WWAN Card Replacement: paso 4, imagen 1 de 2 HP Mini 311 WWAN Card Replacement: paso 4, imagen 2 de 2
    • Lift the memory shield up and remove from the laptop.
  5. HP Mini 311 WWAN Card Replacement, WWAN Card: paso 5, imagen 1 de 3 HP Mini 311 WWAN Card Replacement, WWAN Card: paso 5, imagen 2 de 3 HP Mini 311 WWAN Card Replacement, WWAN Card: paso 5, imagen 3 de 3
    • Begin by removing the red and blue wires from the wireless card.
    • Gently remove to avoid damaging the ends of the wires.
  6. HP Mini 311 WWAN Card Replacement: paso 6, imagen 1 de 1
    • Remove the two Phillips 00 3.8mm screws attached to the wireless card.
  7. HP Mini 311 WWAN Card Replacement: paso 7, imagen 1 de 3 HP Mini 311 WWAN Card Replacement: paso 7, imagen 2 de 3 HP Mini 311 WWAN Card Replacement: paso 7, imagen 3 de 3
    • Lift up the unattached side of the wireless card and pull out to remove.
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 20-4, Maness Winter 2013 Miembro de Cal Poly, Team 20-4, Maness Winter 2013
CPSU-MANESS-W13S20G4
4 Miembros
6 Guías creadas
Un comentario
I don't have red and blue wires visible, are they tucked behind something? My pcie slot is vacant. What compatible part can i put here to increase speed and/or wireless connectivity?
Samant - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 1,435
