Introducción
If you want to increase your computers memory or are having trouble with speed, the RAM is simple to replace in HP Mini 311.
Lay the laptop  on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case. Lay the laptop  on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case. Lay the laptop  on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
  • Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
Agregar Comentario
Slide the battery away from the device to remove. Slide the battery away from the device to remove.
  • Slide the battery away from the device to remove.
Agregar Comentario
Guía de regalos para el día del padre
Honremos a más que nuestros padres—celebremos a todos los mentores que nos enseñaron a reparar.
Honremos a aquellos que nos enseñaron a reparar.
With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
  • With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
  • The screws will remain in the shied.
Agregar Comentario
Lift the memory shield up and remove from the laptop. Lift the memory shield up and remove from the laptop.
  • Lift the memory shield up and remove from the laptop.
Agregar Comentario
Firmly press on the metal pins located on both sides of the RAM. One side of the RAM will pop up to form a 40 degree angle with the body of the laptop. Simply grab and remove the RAM from the device.
  • Firmly press on the metal pins located on both sides of the RAM.
  • One side of the RAM will pop up to form a 40 degree angle with the body of the laptop.
  • Simply grab and remove the RAM from the device.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 20-4, Maness Winter 2013 Miembro de Cal Poly, Team 20-4, Maness Winter 2013
CPSU-MANESS-W13S20G4
4 Miembros
6 Guías creadas
4 GB modules are not supported it seems.
You may see posts in the HP Support Forum saying that the Mini 311 will accept a 4 GB module. Possibly this is true for the Pavilion DM, but not the Mini 311.
The service manual says only 2GB or 1 GB are supported.
Other people posted that they tried a 4GB module and it did not work.
rafss - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 4
Últimos 30 Días: 31
Todo El Tiempo: 2,136
