Saltar al contenido principal
HP Mini 311 Keyboard Replacement
Qué necesitas
  1. HP Mini 311 Keyboard Replacement, Battery: paso 1, imagen 1 de 3 HP Mini 311 Keyboard Replacement, Battery: paso 1, imagen 2 de 3 HP Mini 311 Keyboard Replacement, Battery: paso 1, imagen 3 de 3
    • Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
  2. HP Mini 311 Keyboard Replacement: paso 2, imagen 1 de 2 HP Mini 311 Keyboard Replacement: paso 2, imagen 2 de 2
    • Slide the battery away from the device to remove.
  3. HP Mini 311 Keyboard Replacement, Memory Shield: paso 3, imagen 1 de 1
    • With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
    • The screws will remain in the shied.
  4. HP Mini 311 Keyboard Replacement: paso 4, imagen 1 de 2 HP Mini 311 Keyboard Replacement: paso 4, imagen 2 de 2
    • Lift the memory shield up and remove from the laptop.
  5. HP Mini 311 Keyboard Replacement, Hard Drive: paso 5, imagen 1 de 3 HP Mini 311 Keyboard Replacement, Hard Drive: paso 5, imagen 2 de 3 HP Mini 311 Keyboard Replacement, Hard Drive: paso 5, imagen 3 de 3
    • Grab the left black, plastic tab and carefully pull upward.
    • Be sure to pull carefully. Pulling too forcefully may damage the tab.
  6. HP Mini 311 Keyboard Replacement: paso 6, imagen 1 de 3 HP Mini 311 Keyboard Replacement: paso 6, imagen 2 de 3 HP Mini 311 Keyboard Replacement: paso 6, imagen 3 de 3
    • Grab a hold of the wire connecting the hard drive and the device.
    • Pull upward, perpendicular to the surface of the laptop, releasing the connector tethering the hard drive to the motherboard.
  7. HP Mini 311 Keyboard Replacement, Keyboard: paso 7, imagen 1 de 1
    • Unscrew the four Phillip 00 5.6 mm screws located around the wireless card and RAM.
  8. HP Mini 311 Keyboard Replacement: paso 8, imagen 1 de 1
    • Open the laptop so that the screen and front of the keyboard are both facing the ground.
    • Push on the opening on the back side of the device until the keyboard partially pops out.
    • This opening is located where the original hard drive was set.
  9. HP Mini 311 Keyboard Replacement: paso 9, imagen 1 de 3 HP Mini 311 Keyboard Replacement: paso 9, imagen 2 de 3 HP Mini 311 Keyboard Replacement: paso 9, imagen 3 de 3
    • Flip the device around and orient it so that the screen and keyboard are facing you.
    • Starting at the right side, work your way towards the left end and remove the keyboard by unhinging the latches attaching it to the base of the device.
    • The right side of the keyboard should be unattached.
    • Be gentle and patient. You don't want to pull the entire keyboard at once, but rather pull by sections.
  10. HP Mini 311 Keyboard Replacement: paso 10, imagen 1 de 3 HP Mini 311 Keyboard Replacement: paso 10, imagen 2 de 3 HP Mini 311 Keyboard Replacement: paso 10, imagen 3 de 3
    • Carefully pull the ribbon cable connecting the keyboard and the laptop to remove from the device.
Conclusión
4 personas más completaron esta guía.
Equipo
Cal Poly, Team 20-4, Maness Winter 2013 Miembro de Cal Poly, Team 20-4, Maness Winter 2013
CPSU-MANESS-W13S20G4
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 2,539
