Saltar al contenido principal
HP Mini 311 Hard Drive Replacement
Qué necesitas
  1. HP Mini 311 Hard Drive Replacement, Battery: paso 1, imagen 1 de 3 HP Mini 311 Hard Drive Replacement, Battery: paso 1, imagen 2 de 3 HP Mini 311 Hard Drive Replacement, Battery: paso 1, imagen 3 de 3
    • Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
  2. HP Mini 311 Hard Drive Replacement: paso 2, imagen 1 de 2 HP Mini 311 Hard Drive Replacement: paso 2, imagen 2 de 2
    • Slide the battery away from the device to remove.
  3. HP Mini 311 Hard Drive Replacement, Memory Shield: paso 3, imagen 1 de 1
    • With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
    • The screws will remain in the shied.
  4. HP Mini 311 Hard Drive Replacement: paso 4, imagen 1 de 2 HP Mini 311 Hard Drive Replacement: paso 4, imagen 2 de 2
    • Lift the memory shield up and remove from the laptop.
  5. HP Mini 311 Hard Drive Replacement, Hard Drive: paso 5, imagen 1 de 3 HP Mini 311 Hard Drive Replacement, Hard Drive: paso 5, imagen 2 de 3 HP Mini 311 Hard Drive Replacement, Hard Drive: paso 5, imagen 3 de 3
    • Grab the left black, plastic tab and carefully pull upward.
    • Be sure to pull carefully. Pulling too forcefully may damage the tab.
  6. HP Mini 311 Hard Drive Replacement: paso 6, imagen 1 de 3 HP Mini 311 Hard Drive Replacement: paso 6, imagen 2 de 3 HP Mini 311 Hard Drive Replacement: paso 6, imagen 3 de 3
    • Grab a hold of the wire connecting the hard drive and the device.
    • Pull upward, perpendicular to the surface of the laptop, releasing the connector tethering the hard drive to the motherboard.
Conclusión
4 personas más completaron esta guía.
Equipo
Cal Poly, Team 20-4, Maness Winter 2013 Miembro de Cal Poly, Team 20-4, Maness Winter 2013
CPSU-MANESS-W13S20G4
4 Miembros
6 Guías creadas
Un comentario
What size hard drive does this unit take?
Travis Duncan - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 18
Todo El Tiempo: 4,340
