Introducción
Use this guide to replace your RAM Card. Replacing your RAM card for one of higher capacity will allow your system to perform better.
Herramientas
No se requieren herramientas.
Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
  • Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
  • Close the laptop and turn it over, so that the underside is up and the silver battery bay is facing towards you.
Agregar Comentario
Locate the battery locking latch on the bottom right corner and slide it inward to unlock the battery. Locate the battery release latch on the bottom left and slide it inward. Pull the battery towards you to remove it from the laptop.
  • Locate the battery locking latch on the bottom right corner and slide it inward to unlock the battery.
  • Locate the battery release latch on the bottom left and slide it inward.
  • Pull the battery towards you to remove it from the laptop.
Agregar Comentario
Locate the service access cover release lever and slide it to the right. While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover from the laptop. While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover from the laptop.
  • Locate the service access cover release lever and slide it to the right.
  • While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover from the laptop.
Agregar Comentario
If you are performing any installations after the battery, orient the computer so that the underside is up, and the battery port is facing away from you.
  • If you are performing any installations after the battery, orient the computer so that the underside is up, and the battery port is facing away from you.
Agregar Comentario
Using your fingers, pull the two white clips (tabs) on both sides of the RAM away from each other. Keep pulling the clips until the RAM pops up
  • Using your fingers, pull the two white clips (tabs) on both sides of the RAM away from each other. Keep pulling the clips until the RAM pops up
  • Hold the RAM on the edges only. Touching the components on the RAM might damage it.
Agregar Comentario
Grab the edges of the module and gently lift it from the slot.
  • Grab the edges of the module and gently lift it from the slot.
  • RAM Cards are designed with a notch on the surface to prevent incorrect insertion into the memory module slot.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Sean Kuster
Miembro Desde 05/10/12
73 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 3-23, Amido Fall 2012 Miembro de Cal Poly, Team 3-23, Amido Fall 2012
CPSU-AMIDO-F12S3G23
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 2
Últimos 30 Días: 6
Todo El Tiempo: 1,704
