Introducción
Installing new RAM (random access memory) on your netbook is quick and requires little disassembly.
Turn off and unplug the netbook before replacing the battery. Hold the netbook top-side down with the lid closed.
  • Turn off and unplug the netbook before replacing the battery.
  • Hold the netbook top-side down with the lid closed.
  • Slide the plastic battery release latches towards the lock symbols.
  • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
Agregar Comentario
Slide the battery out from the netbook.
  • Slide the battery out from the netbook.
Agregar Comentario
Turn the netbook to view its edge.
  • Turn the netbook to view its edge.
  • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
  • If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
Agregar Comentario
Pull the back case off from the front edge.
  • Pull the back case off from the front edge.
Agregar Comentario
Push out the two plastic prongs on either side of the RAM.
  • Push out the two plastic prongs on either side of the RAM.
Agregar Comentario
The RAM should pop up allowing for easy removal from its compartment.
  • The RAM should pop up allowing for easy removal from its compartment.
  • Pull out the RAM.
Agregar Comentario
Conclusión
5 personas más completaron esta guía.
Heather Freed
Miembro Desde 06/10/12
582 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 9-17, Amido Fall 2012 Miembro de Cal Poly, Team 9-17, Amido Fall 2012
CPSU-AMIDO-F12S9G17
3 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 4
Últimos 7 Días: 21
Últimos 30 Días: 74
Todo El Tiempo: 5,510
