Saltar al contenido principal
HP G60 Wi-Fi Card Replacement
Qué necesitas
  1. HP G60 Wi-Fi Card Replacement, Battery: paso 1, imagen 1 de 3 HP G60 Wi-Fi Card Replacement, Battery: paso 1, imagen 2 de 3 HP G60 Wi-Fi Card Replacement, Battery: paso 1, imagen 3 de 3
    • First, remove the battery to avoid electric shock
    • Slide and unlock the battery, then lift it
  2. HP G60 Wi-Fi Card Replacement, Wi-Fi card: paso 2, imagen 1 de 3 HP G60 Wi-Fi Card Replacement, Wi-Fi card: paso 2, imagen 2 de 3 HP G60 Wi-Fi Card Replacement, Wi-Fi card: paso 2, imagen 3 de 3
    • Now, you should to remove the Wi-Fi card cover
    • Remove this screw
    • Lift the cover
  3. HP G60 Wi-Fi Card Replacement, Unlock Wi-Fi card: paso 3, imagen 1 de 3 HP G60 Wi-Fi Card Replacement, Unlock Wi-Fi card: paso 3, imagen 2 de 3 HP G60 Wi-Fi Card Replacement, Unlock Wi-Fi card: paso 3, imagen 3 de 3
    • The Wi-Fi card is locked, but you should to change that.
    • Remove this two little screws.
    • Pull the Wi-Fi card.
  4. HP G60 Wi-Fi Card Replacement, Unplug Wi-Fi card: paso 4, imagen 1 de 3 HP G60 Wi-Fi Card Replacement, Unplug Wi-Fi card: paso 4, imagen 2 de 3 HP G60 Wi-Fi Card Replacement, Unplug Wi-Fi card: paso 4, imagen 3 de 3
    • You should to be carefull with the next steps, the plugs are easy to separate, but they are fragile
    • Pull carefully both cables from the Wi-Fi card, it requires a little strength
  5. HP G60 Wi-Fi Card Replacement, Reassemble Wi-Fi card: paso 5, imagen 1 de 2 HP G60 Wi-Fi Card Replacement, Reassemble Wi-Fi card: paso 5, imagen 2 de 2
    • Now it's time to put the new Wi-Fi card
    • Connect both plugs, the cable with white tag, at the left of the Wi-Fi card, the green one, at the right plug
  6. HP G60 Wi-Fi Card Replacement, Data Plug: paso 6, imagen 1 de 3 HP G60 Wi-Fi Card Replacement, Data Plug: paso 6, imagen 2 de 3 HP G60 Wi-Fi Card Replacement, Data Plug: paso 6, imagen 3 de 3
    • The Wi-Fi card already has the power plugs, now it's time to the data plug
    • Insert the Wi-Fi card in a 45 degrees angle
    • Now press it and screw it
  7. HP G60 Wi-Fi Card Replacement, Reassemble cover: paso 7, imagen 1 de 3 HP G60 Wi-Fi Card Replacement, Reassemble cover: paso 7, imagen 2 de 3 HP G60 Wi-Fi Card Replacement, Reassemble cover: paso 7, imagen 3 de 3
    • For finish, reassemble the cover
    • If the cover is still lifted, press softly until you hear a click
Linea de Meta
6 personas más completaron esta guía.
jimenezser
Miembro Desde 08/29/12
3,848 Reputación
4 Guías creadas
4 comentarios
If the button that turns blue when I start my computer stays orange does that mean I need to install a new wifi card?
veronica - Contestar
Hi frnd just want to know ur hp laptop button was not working it stayed orange thn what did u do? U changed wifi card or button plz reply me i have same condition can u ans me on my mobile whatsapp plz +85254077440
saqib raheem -
Please provide information on the model of the wifi card
thaisabs - Contestar
My card wifi on laptop G60-530US was not working. Can you suggest me some modle of new card wifi which can be suitable my laptop. Thanks so much
tech - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 10
Ultimos 30 días: 20
Todo El Tiempo: 3,797
