Herramientas
No se requieren herramientas.
First, you should to remove the battery to avoid electric shocks Slide and unlock the battery, then, lift it Slide and unlock the battery, then, lift it
  • First, you should to remove the battery to avoid electric shocks
  • Slide and unlock the battery, then, lift it
Agregar Comentario
Remove the two screws with a not too large screwdriver Now lift the cover, the screws are part of the cover Now lift the cover, the screws are part of the cover
  • Remove the two screws with a not too large screwdriver
  • Now lift the cover, the screws are part of the cover
Agregar Comentario
Guía de regalos para el día del padre
Honremos a más que nuestros padres—celebremos a todos los mentores que nos enseñaron a reparar.
Honremos a aquellos que nos enseñaron a reparar.
Push the little aluminum locks at the top and the bottom of the ram The memory will lift, then pull it Make this with the another RAM slot
  • Push the little aluminum locks at the top and the bottom of the ram
  • The memory will lift, then pull it
  • Make this with the another RAM slot
Agregar Comentario
The new RAM memory should to be insert in a 45 degrees angle Then, push it and the memory will lock by itself Make this with the second memory
  • The new RAM memory should to be insert in a 45 degrees angle
  • Then, push it and the memory will lock by itself
  • Make this with the second memory
Agregar Comentario
Insert the cover from right to left, then, screw it If cover is lifted, press it softly and secure it If cover is lifted, press it softly and secure it
  • Insert the cover from right to left, then, screw it
  • If cover is lifted, press it softly and secure it
Agregar Comentario
Linea de Meta
4 personas más completaron esta guía.
jimenezser
Miembro Desde 29/08/12
3,241 Reputación
9 Guías creadas
Thanks for verifying the RAM replacement and that it was as easy as I thought it was, but that made me a bit nervous, being much more comfortable building desktops as large as my or my customer's budget would allow!
Take 'em out, put new ones back in. As a technical writer, I also appreciate that you kept it to the point without creating further questions to complicate that which is not complicated. Thanks again. Will check out some out your other work.
J Brent Masters - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 9
Últimos 30 Días: 30
Todo El Tiempo: 4,750
