Saltar al contenido principal
HP Envy x360 15-u473cl Touch Screen Replacement
Qué necesitas
  1. HP Envy x360 15-u473cl Touch Screen Replacement, Touch Screen: paso 1, imagen 1 de 2 HP Envy x360 15-u473cl Touch Screen Replacement, Touch Screen: paso 1, imagen 2 de 2
    • Remove the two anti-tamper covers from the bottom corners of the screen using the spudger which will reveal two screws.
    • Remove the two 3mm screws using the J00 Phillips screwdriver.
  2. HP Envy x360 15-u473cl Touch Screen Replacement: paso 2, imagen 1 de 1
    • Move the plastic opening tool along the seem while prying up to separate the display housing from the laptop cover.
    • If the touch screen housing is cracked, it may splinter or shatter while separating.
  3. HP Envy x360 15-u473cl Touch Screen Replacement: paso 3, imagen 1 de 1
    • Remove the four 3mm screws using the Phillips #00 screwdriver.
  4. HP Envy x360 15-u473cl Touch Screen Replacement: paso 4, imagen 1 de 2 HP Envy x360 15-u473cl Touch Screen Replacement: paso 4, imagen 2 de 2
    • Lift the white UPC tape using the spudger, and disconnect the the golden connector from the screen.
    • There may be a piece of black tape connecting a bundle of wires to the screen. Remove the piece of black tape if present.
    • Remove the touch screen.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 45
Todo El Tiempo: 12,761
