Introducción
The motherboard can wear out over time. This guide will show you how to replace the motherboard.
Qué necesitas
Pry off the 2 rear rubber pads (closest to the laptop hinge) using the plastic opening tool to reveal two screws.
Remove the 2 anti-tamper proof covers using the spudger to reveal two screws.
Remove the three 4mm screws using the Phillips #0 screwdriver from the device fan.
Remove the five 4mm screws with the Phillips #0 screwdriver.
Remove one 3mm screw with the Phillips #00 screwdriver.
2 personas más completaron esta guía.
