Saltar al contenido principal
HP Envy 17-J013CL Battery Replacement
Qué necesitas
  1. HP Envy 17-J013CL Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Lay the laptop with the battery facing towards you.
    • Remember to disconnect the AC cable and other power sources from the device before replacing/repairing parts.
  2. HP Envy 17-J013CL Battery Replacement: paso 2, imagen 1 de 1
    • Grab hold of the small battery slider and apply pressure to the right.
    • The laptop itself will push the battery out for you once the switch slides all the way to the right.
  3. HP Envy 17-J013CL Battery Replacement: paso 3, imagen 1 de 3 HP Envy 17-J013CL Battery Replacement: paso 3, imagen 2 de 3 HP Envy 17-J013CL Battery Replacement: paso 3, imagen 3 de 3
    • Pull the battery out and let go of the battery slider.
Conclusión
To reassemble your device, line up the battery and place it down into the metallic prongs for a stable connection.
2 personas más completaron esta guía.
Matt McBride
Miembro Desde 02/02/17
845 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 16-6, Blackwell Spring 2017 Miembro de USF Tampa, Team 16-6, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G6
3 Miembros
6 Guías creadas
Un comentario
where does one buy a replacement battery for this HP envy17?
brandondelcastillo - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 1,963
