Saltar al contenido principal
HP Elite x2 G4 Battery Replacement
Qué necesitas
  1. HP Elite x2 G4 Battery Replacement, Display Assembly: paso 1, imagen 1 de 1
    • Open the kickstand.
    • Remove the four 3 mm T5 Torx-head screws that secure the display assembly.
  2. HP Elite x2 G4 Battery Replacement: paso 2, imagen 1 de 1
    • Use a suction sup to carefully detach the display assembly in the following order: top-right corner, top-left corner, bottom-right corner and bottom-left corner.
  3. HP Elite x2 G4 Battery Replacement: paso 3, imagen 1 de 1
    • Slowly lift the display panel until you have access to the battery connector on the motherboard (approx. 90 degrees).
  4. HP Elite x2 G4 Battery Replacement: paso 4, imagen 1 de 1
    • Disconnect the battery cable from its motherboard connector.
    • Remove the tape that covers the touchscreen and display panel ZIF connectors.
  5. HP Elite x2 G4 Battery Replacement: paso 5, imagen 1 de 1
    • Disconnect the touchscreen ribbon cable from the motherboard.
    • Remove the display panel assembly.
  6. HP Elite x2 G4 Battery Replacement, Battery: paso 6, imagen 1 de 1
    • Remove the six 3.5 mm Phillips #1 screws that secure the battery to the display enclosure.
  7. HP Elite x2 G4 Battery Replacement: paso 7, imagen 1 de 1
    • Carefully lift the top edge of the battery off of the alignment pins.
    • Remove the battery.
  8. HP Elite x2 G4 Battery Replacement: paso 8, imagen 1 de 1
    • Slide the bottom edge out from retention tabs on the display enclosure and remove.
Conclusión
Una persona más ha completado esta guía.
Goncalo Felix
Miembro Desde 10/25/22
325 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 4-4, Sinclaire Fall 2022 Miembro de UMass Dartmouth, Team 4-4, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G4
5 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 22
Ultimos 30 días: 140
Todo El Tiempo: 1,225
