Introducción
The keyboard and touchpad of your HP Chromebook 14-Q010DX are essential for typing, scrolling, and navigating your laptop. If they are damaged or malfunctioning, you may want to replace them with a new part. The repair should take 5-10 minutes and this guide will help you to replace the Keyboard and touchpad and will show you how to open the laptop, disconnect the old part, and connect the new one. You will need a new keyboard, touchpad, a Phillips #00 screwdriver, a Spudger and an iFixit opening tool which can be found online.
Qué necesitas
Flip the laptop with the base of the laptop is facing you.
Using the #00 screwdriver, unscrew these screws.
17 personas más completaron esta guía.
10 comentarios
In the black variant of this model I found that there are two screws under the rubber feet near the hinge.
This was very close to a similar HP Chromebook I had to repair recently. Such a beautiful and simple process. I cleaned the keyboard connectors and everything functioned perfectly after I was done. The whole process took about 30 minutes (allotting 10 minutes to find my rubbing alcohol that my wife hid from me).
Any idea how to get the replacement keyboard?
At the top of this page under "Relevant parts" there is a link to purchase the keyboard replacement.
