Saltar al contenido principal
HP 7 Plus 1302 Battery Replacement
Qué necesitas
  1. HP 7 Plus 1302 Battery Replacement, Back Cover: paso 1, imagen 1 de 1
    • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
    • Device should be turned off and unplugged before starting the replacements.
  2. HP 7 Plus 1302 Battery Replacement: paso 2, imagen 1 de 2 HP 7 Plus 1302 Battery Replacement: paso 2, imagen 2 de 2
    • Use the plastic opening tool to push in between the front and the back of the tablet.
    • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
    • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
  3. HP 7 Plus 1302 Battery Replacement: paso 3, imagen 1 de 2 HP 7 Plus 1302 Battery Replacement: paso 3, imagen 2 de 2
    • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
    • Remove the back cover.
  4. HP 7 Plus 1302 Battery Replacement, Battery: paso 4, imagen 1 de 2 HP 7 Plus 1302 Battery Replacement, Battery: paso 4, imagen 2 de 2
    • Push out the battery connector using the spudger.
    • Swing the battery connector clear of the connector socket.
  5. HP 7 Plus 1302 Battery Replacement: paso 5, imagen 1 de 1
    • Lift the battery from the device.
Conclusión
To reassemble your device, follow these instructions in reverse order. Use new double sided tape to secure the new battery.
Una persona más ha completado esta guía.
Jason
Miembro Desde 07/07/15
101 Reputación
1 Guía escrita
Equipo
IUPUI, Team 1-2, Renguette SU 2015 Miembro de IUPUI, Team 1-2, Renguette SU 2015
IUPUI-RENGUETTE-SU15S1G2
5 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 1,751
