Saltar al contenido principal
GoPro Hero5 Black Back Housing Replacement
Qué necesitas
  1. GoPro Hero5 Black Back Housing Replacement, Battery: paso 1, imagen 1 de 3 GoPro Hero5 Black Back Housing Replacement, Battery: paso 1, imagen 2 de 3 GoPro Hero5 Black Back Housing Replacement, Battery: paso 1, imagen 3 de 3
    • While pressing the button on the bottom of the GoPro, slide the battery door to the side to pop it open.
  2. GoPro Hero5 Black Back Housing Replacement: paso 2, imagen 1 de 3 GoPro Hero5 Black Back Housing Replacement: paso 2, imagen 2 de 3 GoPro Hero5 Black Back Housing Replacement: paso 2, imagen 3 de 3
    • Grab the plastic flap on the battery and pull the battery out.
  3. GoPro Hero5 Black Back Housing Replacement, Back Housing: paso 3, imagen 1 de 2 GoPro Hero5 Black Back Housing Replacement, Back Housing: paso 3, imagen 2 de 2
    • Pull and twist the lens cover right or left until it pops off.
    • The lens cover is secured tightly and might be difficult to twist off.
  4. GoPro Hero5 Black Back Housing Replacement: paso 4, imagen 1 de 1
    • This step is not necessary but will make the process of removing the faceplate much easier.
    • Refer to the iOpener instructions for how to heat up and use the iOpener.
    • Apply the heated iOpener to the front of the GoPro for a few minutes to melt the adhesive under the faceplate.
    • The heated iOpener is very hot and can burn your hands. Avoid burns by using towels or gloves to hold the iOpener.
  5. GoPro Hero5 Black Back Housing Replacement: paso 5, imagen 1 de 3 GoPro Hero5 Black Back Housing Replacement: paso 5, imagen 2 de 3 GoPro Hero5 Black Back Housing Replacement: paso 5, imagen 3 de 3
    • Starting with the edges, use the spudger to pry off the faceplate.
    • The faceplate is held down with adhesive and may take a while to get off.
  6. GoPro Hero5 Black Back Housing Replacement: paso 6, imagen 1 de 2 GoPro Hero5 Black Back Housing Replacement: paso 6, imagen 2 de 2
    • Remove the six T3 Torx screws.
  7. GoPro Hero5 Black Back Housing Replacement: paso 7, imagen 1 de 3 GoPro Hero5 Black Back Housing Replacement: paso 7, imagen 2 de 3 GoPro Hero5 Black Back Housing Replacement: paso 7, imagen 3 de 3
    • Be careful when pulling open the motherboard assembly as it is still connected to the back housing by four cables. The cables may break if stretched.
    • Using the spudger, slowly pry open the motherboard assembly from the LCD side of the GoPro.
  8. GoPro Hero5 Black Back Housing Replacement: paso 8, imagen 1 de 3 GoPro Hero5 Black Back Housing Replacement: paso 8, imagen 2 de 3 GoPro Hero5 Black Back Housing Replacement: paso 8, imagen 3 de 3
    • Use the flat end of a spudger to pry the three ribbon cables connected to the side of the motherboard.
  9. GoPro Hero5 Black Back Housing Replacement: paso 9, imagen 1 de 2 GoPro Hero5 Black Back Housing Replacement: paso 9, imagen 2 de 2
    • Use the flat end of the spudger to pry the battery housing power cable straight up from its socket on the motherboard.
Conclusión
16 personas más completaron esta guía.
Equipo
Cal Poly, Team 18-6, Forte Fall 2016 Miembro de Cal Poly, Team 18-6, Forte Fall 2016
CPSU-FORTE-F16S18G6
4 Miembros
22 Guías creadas
2 comentarios
Where can you get replacement rear screens for this
ociaravella - Contestar
Hi, how i reset firmware in this gopro? I have a problem with a bucle starting and it dont turn on, always restarting.
ISU AREY - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 29
Ultimos 30 días: 126
Todo El Tiempo: 23,294
