Saltar al contenido principal
GoPro Hero3+ Silver Edition Front Panel Replacement
Qué necesitas
  1. GoPro Hero3+ Silver Edition Front Panel Replacement, Front Panel: paso 1, imagen 1 de 1
    • Insert a plastic opening tool in between the front face plate and the black housing.
    • Make sure you insert the plastic opening tool next to the microSD card slot. There is a small gap that will help separate the face plate.
  2. GoPro Hero3+ Silver Edition Front Panel Replacement: paso 2, imagen 1 de 1
    • Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
    • There is adhesive that helps attach the front face plate. Some extra prying may be required to separate the face plate, but do not use excessive force.
Conclusión
4 personas más completaron esta guía.
Patrick Cook
Miembro Desde 10/01/15
687 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 5-8, Maness Fall 2015 Miembro de Cal Poly, Team 5-8, Maness Fall 2015
CPSU-MANESS-F15S5G8
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 6
Todo El Tiempo: 570
